Not sure if Mach runs on 2000 server? Although if the drivertest works, I guess it should.
Have you tried using outputs, and measuring voltage on the direction pin while jogging? Do the DR's change? Is the Estop wired to an external switch, or breakout board?
LinkBack URL
About LinkBacks
