| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
This is just to satisfy curosity...... When I set up my plasma table Mack Kernel Speed is set to 25000Hz & was told to leave that alone. When, What, Why are the higher kernel speeds used ?
__________________ If it works.....Don't fix it! |
| If the kernel frequency is limiting your top speed, then you use a faster one. For example, if you use a 10 turn/inch screw, and a 10 microstep drive, you need 20,000 steps per inch. At 25KHz, you get 25,000 steps/second, which will limit you to 75 ipm. If you want to go faster, you need a higher kernel speed.
| I really wasn't having a problem. I was set at 25000 Kernel Speed & have apx 450 IPM rapids at that. I just re set to 35000. I was able to ease the rapids on to 550 IPM. The steppers seem much happier there too. I tried speeds just above 600 IPM but but began to loose steps. I'm sure I was trying to out run my processor. The gantry would accelerate fine but I could hear it every now & then glitch a bit. Then when returning home & referencing the gantry I could see it take just a bit of twist out. Set the speeds back down a bit & paced the gantry through about a 10 min. program at 200 IPM simulated cut speeds without a glitch. Motor seem to be even quieter at low speeds around 20IPM too. I was afraid to try it without asking for fear of overheating my drives etc.
| Newbie- G Codes for Dummies | bdtutton | General Metal Working Machines | 2 | 01-21-2009 02:51 PM |
| CNC for dummies | 300magnum | Benchtop Machines | 3 | 02-11-2008 11:54 AM |
| Mach3 for Dummies and | CompositeCraft | Machines running Mach Software | 7 | 01-29-2008 12:23 PM |
| pwm for dummies | Mcgyver | General Electronics Discussion | 11 | 04-18-2005 10:08 PM |
| CNC for dummies | Jan-Roger | DIY-CNC Router Table Machines | 1 | 11-27-2004 03:48 PM |
