01-11-2010, 08:07 PM
Spindle won't run, flashes speed then 0 | | Just setting up, the x-y setup works great, followed instructions best as i could spent 8 hours today. I have no limit switches or home, no encoders, no start stop buttons, disabled all in/out ports. turned off watchdog and any other things i could find? Its not a pin issue because i used the same ones as the x-y
( yes disabled them first on x-y) I have been running them without being hooked to ports as well ( the mach3 software is doing this )
1.8 deg stepper motor in half step
set per at 400 vel 50 step pulse 1 dir 0
have using spin motor and step/ dir checked
it acts like it is looking for some feed back of some sort, of which i thought i have disabled?
both lathe and mill do the same thing, it flashes the speed for a second then the lathe shows a yellow bar undernieth the mill flashes around the speed box along with the dwell box flashing,
m3 s100
gcodes
m5
it stops on m3 and flashes speed once and wont move on, like its waiting for something? its going super slow I dont want all the safety switches and buttons
what am I doing wrong or exactly what to i need to do for settings? thanks in advance Steve |
