Results 1 to 8 of 8
Thread: Mach3 on a netbook...
    Registered LongRat's Avatar
    Apr 2005
    UK
    I'd like to run my large 'outdoor' mill on a netbook, as I would like to avoid leaving the PC with the mill. The Acer Aspire One series of netbooks have caught my eye.
    Before I go ahead and get one, does anyone have any experiences (good or bad) trying this. How well does Mach3 run on these machines? I will have to use a SmoothStepper as there won't be a parallel port of course. I also have doubts about interfacing a pendant with this netbook/smoothstepper set up. I won't have a serial port either. Really like the look of the Homann pendants but do they require a serial connection?
    Thanks!
    Mar 2003
    Shelby Twp, MI....USA
    You can always make your own pendant and connect it to the Smoothstepper.
    I know people run Mach3 on Atom desktop PC's with Smoothsteppers, so it should run OK on the Netbook. The Smoothstepper takes most of the load off the PC.
    Apr 2005
    UK
    That was what I was assuming and hoping.
    I guess any pendant that uses Modbus would not work? I don't have a problem making my own, but I would be interested in any SmoothStepper-compatible pendants out there that may be available.
    Mar 2003
    Any pendant that plugs into a parallel port should work with the Smoothstepper.
    Here's a USB pendant, but not cheap.
    http://campbelldesigns.net/CNC%20min...dant%20MP1.php
    Apr 2005
    UK
    Yes, that's costly.
    What about using a converter cable for USB to serial, such as this one on the CNC4PC site: http://www.cnc4pc.com/Store/osc/prod...1fb0c8a4b3ef52
    That says it is suitable for connecting a Modbus server. Maybe a Modbus based pendant would work with it? Or I could just get one of his LPT port pendants and plug that into the SS.
    Mar 2003
    I don't really know anything about how Modbus works.
    Dec 2004
    Quote Originally Posted by LongRat View Post
    Yes, that's costly.
    It should work with the usb to serial converter.
    Apr 2005
    UK
    Good info, thanks TRC.
    1. Need Help!- Mach3
      By AngelT in forum Mach Mill
      Last Post: 06-28-2008, 02:51 PM
    2. Mach3
      By shogunyabu in forum Spanish CNCzone
      Last Post: 04-19-2008, 12:22 PM
    3. New Machine Build- MACH3
      By esawyja in forum Machines running Mach Software
      Last Post: 02-20-2008, 01:14 AM
    4. G-Rex & mach3
      By eloid in forum Machines running Mach Software
      Last Post: 03-15-2007, 12:50 AM
    5. Mach3 and USB
      By mikep608 in forum Mach Mill
      Last Post: 08-09-2006, 01:56 AM
