Old 12-25-2009, 11:17 PM
Tony611 is on a distinguished road
Mach3 blue screen
This is the path that I took in Mach3 view, Load screens, addons, circle center, circle center set the back to mach3. Now all I have is a blue screen. What did I do wrong and how do I get the main screen back?
Old 12-26-2009, 03:14 AM
M250cnc's Avatar
M250cnc is on a distinguished road
Tony,
You went wrong by selecting a screen out of the main Mach3 folder, just go back to the main Mach3 folder
Lathe screen files end in *.lset, mill is *.set
So if you are using lathe you have to change the files of type to suit your machine
If you want to use a third party screenset it may have to have the bitmap files added to the folder BITMAPS there are two folders there one for lathe and one for mill
Phil
Old 12-26-2009, 09:45 AM
ger21's Avatar
View>Load Screens and choose 1024.set in the main Mach3 folder.
You tried to load a wizard screen. You need to just run the wizard from Mach3.
Old 12-26-2009, 10:55 AM
Thanks for the help. The 1024 did the trick.
Only get blue screen gabby Cincinnati CNC 3 12-16-2009 12:14 PM
Mach3 Mill Blue Screen of Death. Dougal Mach Mill 1 09-27-2009 07:06 PM
Need Help!- Mach3 View Screen too BIG Mr.Chips Mach Mill 1 01-01-2009 03:35 PM
blue screen of death norvil1 Machines running Mach Software 4 10-15-2006 03:24 PM
Mach3 screen set PEU Screen Layouts, Post Processors & Misc 1 10-25-2005 05:27 PM
