| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I need help! I run Mach2 on a DIY cnc machine that uses X, Y, Z movements like a milling machine, but is acutally a lathe for turning pool cue shafts. My first dilemma is setting up an A axis. I have a stepper hooked up to the spindle of my lathe. I want to use it to index for inlay work. The problem is that I do not know how to command it. When I write G1 A90, the axis tries to move to a linear position of 90. I have the axis set to angular in config>logic, but it still does not work properly. My second dilemma is that I want to use the same stepper as a spindle motor for turning operations. I have tried numerous configurations and had no success. I am rather self taught, and can't figure this out. any help would be greatly appreciated. Royce |
| Do you have your steps/unit set correctly? What do you mean it's trying to move linearly? I think you'll need 2 seperate configurations if you want to use it as the spindle. You'll have to disable it as A for spindle use I think. For spindle use it should be controlled by using S. CHeck the manual for more info, as I'm just guessing here.
| Ger21 I know I am looking for two different setups, I want to save them as different profiles so that I can open Mach2 with one profile for turning and the other for inlays. Since my last post I have been able to make the a axis work. I select a axis in the port setup and designated the correct output pins. (I had done all that before). I set A to angular in Logic configuration. I was able to command g1 A.5, and get it to rotate to 180 degrees. When I go to A1, it comes aroung to the top again, but the DRO shows 1.000. I did some inlay with this and it worked by dividing the number of inlays in the full circle into 1. Four inlays would be .25, .50 .75 and 1 or zero again. I don't htink this is right, it just seems odd. I followed the manual although I can't seem to find the pages right now. It is getting late, and the pages are beginning to all look the same. I have not been able to make the stepper spin as though it is a spindle drive motor though. I have played with the pulley settings and the motor tuning, but I get yellow flashing lights when I enter an M3 or M4 to get the motor running. I will have to pick it up on Tuesday, when I can get back to the machine. Royce |
| M3 or M4 are usually used to turn on a relay. Not sure if that's how you would start the stepper spindle? Here's what the manual says:
| Ger21 I think I have gone through the manual so many times it is all running together. I have set up all of these parameters. I checked the spindle axis enable box. I defined the output pins for spindle step and direction. I defined external activation signals. I set the spindle axis units in motor tuning. I used 1600 for the units (200steps *8 for Xylotex microstep). I set the Vel box to 3.333 (200rpm max/60) I have played with the accel box, both low and high. When I go to the MDI screen and command S100, it changes the DRO speed to 100 just like it is supposed to. But when I try to start the spindle, all I get is a yellow light flashing in the DRO display. If I hit reset or type in an M5 command, it will stop. I get the same yellow flash if I command an M3 or M4. I have also played with the pulley settings. My actual pulley arrangement on the machine is 1 to 1, so I don't need any reduction or multiplication. I currently have the software set to pulley #4, with a max speed of 1000. If there is anyone out there who has used Mach2 to drive a stepper for spindle control I would love to see your setup. I know it is something simple that I am not doing right, I just don't know what it is. I love this software, but this is an important function that I must have. I have not purchased the activation yet because I have not been able to get this to work. I really like everything about the program, I just need to be able to get this to work. Royce |
| Boy do I feel dumb!! I went through the setups again last night and I found my error. I had not changed the port # from 0 to 1 for the spindle. I had set the step and direction numbers properly, I had just not told it which port is was coming from. So anyway, the spindle is now spinning properly. I have to work out the speed, and make sure that it is right, but I will have to wait until tonight for that. Thanks to all for all your help. I know I found my own problem, but I would have still been thinking there was some setup that I had not found if you guys had not pointed me back in the same direction. Royce |
Hi Royce, thanks for sharing ur experience. I am trying to do the same thing with my machine which is in transit now. Refer to the following link which may help. http://www.machsupport.com/forum/ind...c,11422.0.html Sounds like ur missing an indexing component to do ur inlays. Let me know what u think. Norman
| CNC Glossary | CNCadmin | CNCzone Club House | 17 | 03-09-2008 03:08 PM |
| Series 2 BOSS 6 Axis motion problem | craig96us | Bridgeport and Hardinge Mills | 43 | 01-14-2006 11:06 AM |
| Beta Testers for QMill/CNC discussion | CNCadmin | General CNC (Mill and Lathe) Control Software (NC) | 18 | 11-25-2005 12:33 PM |
| Dirction / Step lines! | bigal | TurboCNC | 2 | 02-06-2005 01:51 PM |
| PIN OUT 4th axis | Snel | Haas Mills | 1 | 01-12-2004 11:13 PM |
