Old 11-27-2009, 05:20 PM
RedLabel is on a distinguished road
Add on PCI parallel port and Mach
I was using mach with my cnc with great success 2 years ago (tried emc2, turbo cnc but mach seems to run better).
Unfortunately my previous motherboard is not working anymore. The new motherboard I purchased supposed to have parallel port but it turned out to be an "updated" version with 8 usb ports in the back lots of other ports but NO parallel port.
I did not use my cnc for the last year but now I'm planning to return to hobby and trying to figure out a way to use my new desktop with the boards like xylotex.
From the operation of usb ports it seems impossible to generate the signals needed for the controller so I ruled out simple usb to parallel port converters.
What about add-on pci parallel port cards? I think they should work properly.
http://www.newegg.com/Product/Produc...82E16815166007
Planning to purchase the card above. It can support up to to parallel ports. Do you think it will work well?
Suggestions are welcome...
Old 11-30-2009, 04:57 PM
Torchhead is on a distinguished road
That card has the MOSCHIP chip set that has worked well for us in the past with MACH.
Chipset: MOSCHIP MCS9815CV
One thing we have had trouble with is trying to take a PC that is designed to run Vista and make it work with XP and some of the cards. Took several tries with different drivers to make it work.
I have been buying refurbed HP's and Dell's that have XP PRo installed, 3G processor, 1G Ram and new keyboard and Mouse for 139 to 159 bucks. They have a built in parallel and serial port and some USB.
TOM Caudle
www.CandCNC.com
Old 11-30-2009, 11:14 PM
thanks for the reply.
It will be easier for me to put a pci card to my current computer since I am thinking of putting the router in the same room.
But for the price of 140-150 i would definitely look into getting one of those refurbs. May I ask you where can I purchase one ?
Old 12-03-2009, 01:09 AM
Ebay id # 140364485201
Mach, where's parallel port? daisydog Mach Mill 15 09-10-2009 10:40 AM
Mach & PCI Parallel Port JeLC Mach Software (ArtSoft software) 7 05-28-2009 05:33 AM
parallel port or parallel universe bruno34 Taig Mills & Lathes 5 04-15-2009 10:58 AM
USB to Parallel port? TheDude Hobbycnc (Products) 6 03-24-2008 11:04 AM
Second parallel port? essa LinuxCNC (formerly EMC2) 11 04-12-2006 02:18 AM
