Old 11-23-2009, 05:14 PM
m1911bldr is on a distinguished road
Verified Auto Tool Zero for Ver .032, SmoothStepper, G540
I finally found a VB script that works reliably with the new versions of Mach 3 and SMoothStepper/G540 dirvers. Three notes about this script: 1) Add your Z plate/probe height and the distance you want Z to retract and enter the total dimension in the "change the Z retract height here... line; 2) This script works with the standard MAch screens but I don't know if it will work with any of the modified screens; 3) Probe input signal High/Low must be correct or you'll get the "Z plate is grounded" error. No need to enter the tool gage height or any other parameters.
CurrentFeed = GetOemDRO(818) 'Get the current feedrate.
PlateThickness =2.040
If GetOemLed (825)=0 Then
DoOEMButton (1010)
Code "G4 P3" 'Time to get to the z-plate, 3 seconds
Code "G90 G31 Z-2 F4" ' probing move, can set the feed rate here as well as how far to move
While IsMoving()
Wend
ZProbePos = GetVar(2002)
Code "G1 Z" &ZProbePos
While IsMoving ()
Wend
Call SetDro (2, PlateThickness)
Sleep(120)
Code "G0 Z2.785" 'Change the Z retract height here to what you want, must be higher than touch plate
Code "(Z axis is now zeroed)"
Code "F" &CurrentFeed 'returns to prior feedrate
Else
Code "(Z-Plate is grounded, check connection and try again)"
End If
Exit Sub
Old 12-05-2009, 01:07 AM
jordie1944 is on a distinguished road
Revised tool Zero with smoothstepper
I had problems with the tool zero macro and smooth stepper, it was never spot on so I have revised the macro in this thread to do two probes the first one is a fast one the second is retracted 20 mm and probed at a slower speed. It also uses a user DRO to get the plate thickness and is in metric. It works perfectly every time.
PlateThickness = GetUserDRO(1151) 'Z-plate thickness DRO
If GetOemLed (825)=0 Then 'Check to see if the probe is already grounded or faulty
DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
Code "G90 G31 Z-160 F600" ' probing move, can set the feed rate here as well as how far to move
While IsMoving() 'wait while it happens
Wend
Sleep(120)
Code "G1 Z20" 'retract 20mm and probe again
Code "G90 G31 Z-160 F100" ' prob again, can set the feed rate here as well as how far to move
Wend
Sleep(120)
Sleep(120)
ZProbePos = GetVar(2002) 'get the axact point the probe was hit
While IsMoving ()
Wend
Sleep(120)
Code "G0 Z20" 'Change the Z retract height here to what you want, must be higher than touch plate
Else
End If
Exit Sub
Auto tool zero wildcat Mach Mill 30 10-08-2010 11:03 AM
G540 and SmoothStepper Nzoldun Gecko Drives 2 07-31-2010 11:22 AM
Mach3 + SmoothStepper + G540 = No go CarbonKevin Mach Software (ArtSoft software) 2 11-23-2009 05:09 PM
G540 and Smoothstepper escott76 Benchtop Machines 28 08-28-2009 02:24 PM
auto tool zero help 15mgtar Mach Software (ArtSoft software) 3 08-12-2009 09:16 AM
