Old 11-17-2009, 04:48 PM
Rees Guitars is on a distinguished road
Mach 3 units problem
Hello,
Just about have my Solsylva set up, and have finally had the time to learn my modeling and cam programs.
When I run a program to cut a 4 inch square pocket, the machine wants to cut about 100 inches. This is obviously a mm/inch problem but I haven't found a unit option yet that has fixed the problem. The native units change nothing. Tried modeling it in both mm and inches, nothing... I also plugged in someone else's gcode and got the same problem.
Thanks,
Ed
Old 11-17-2009, 04:51 PM
ger21's Avatar
Assuming your native units are inches, I'll need to see the g-code. What CAM are you using?
Also, you can't just change native units without restarting mach and possibly changing motor tuning.
Old 11-17-2009, 05:19 PM
Yes, they are inches. I'm using Solidcam. G code is attached.
Thank you.
Old 11-17-2009, 05:30 PM
ger21's Avatar
SolidCAM is exporting the code in mm's. If you add a G21 at the top of the code, it should cut the correct size. You may need to use a different post, but I don't know anything about SolidCAM.
Old 11-19-2009, 01:33 PM
Fixed it, thanks!
mach 3 problem ellard Machines running Mach Software 4 04-15-2009 06:53 PM
little problem with mach or something else? ataxy Mach Mill 2 01-30-2008 07:27 AM
Help! anybody have this problem w/ Mach 3? sconklin Mach Mill 6 09-18-2007 06:54 AM
Anybody had this problem in Mach 3? pointcloud Mach Mill 3 07-13-2007 08:09 AM
mach 2 problem CNCadmin Mach Software (ArtSoft software) 5 01-16-2005 02:12 PM
