| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I've just completed my first router, and am beginning testing of the unit. I've not set up home or limit switches; merely bridged the limit switch connections to simulate the "NC" state of each switch. I've got the G540 Mach 3 XML file loaded. I can use the jog functions; both keyboard and the GUI arrows that come up when you hit "tab". The unit jogs just fine this way. I see a common question is, "do the steppers lock up when the program starts" - yes! When I do the circle wizard, I can post the G-code and a toolpath is generated. Back to the main screen, I can hit Cycle Start, the steppers unlock (I think?) and after a few seconds, an error comes up saying "The Smoothstepper ran out of data" and such and such. I should also note that I'm running the demo version of Mach3, as I want to verify that the thing works before I drop (more) money on this project of mine. Thanks in advance for the help! Kevin Last edited by CarbonKevin; 11-14-2009 at 06:57 PM. Reason: mo' info! |
| Never used a Smoothstepper, but from what I've read, you may be getting interference on the USB, and/or losing connection to the Smoothstepper.
I had basically the same issue. I turned down the data stream speed in SmoothStepper config to 1KHz (don't remember it's actual name but it's th etop left-hand window in the SmoothStepper config menu (PlugIn menu bar)) and turned off the USB power saver function in the Device Manager (Control Panel/System/Device Manager/USB Port Hub controller (all of them)/Properties/Power Management). Cleared up my "Timeout error retrieving data" and the "SmoothStepper ran out of data" issues. |
| G540 E-stop and Mach3 | Astroguy | Gecko Drives | 24 | 02-02-2012 10:10 PM |
| G540 and SmoothStepper | Nzoldun | Gecko Drives | 2 | 07-31-2010 11:22 AM |
| G540 and Smoothstepper | escott76 | Benchtop Machines | 28 | 08-28-2009 02:24 PM |
| G540 Mach3 XML File | CoAMarcus | Gecko Drives | 4 | 11-07-2008 11:38 PM |
| Need Help!- SmoothStepper and Mach3 setup | jeffmorris | Mach Software (ArtSoft software) | 0 | 09-02-2008 03:09 PM |
