| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
i have watched the install vids and did everything as said but when testing the driver with driver test(takeover) my bit rate saiys to fast then to slow then levels at 62 uS is this ok, i have slight variations but nothing major , basicly looks like the vids but just instead of 38uS im at 62 uS , i cant make the motors move for anything . been at it for about a week now . any help would be greatly appreciated... |
| It's unlikely that the driver test results are causing a problem. My laptop is terrible with the driver test, but it'll move the motors, although very roughly. How are you trying to move the motors? Jog? Gcode? MDI? Do the DRO's show movement when you try to move? Do the motors lock up when you power up the drives?
| yes the dros show movement when i jog with the arrow keys on my keyboard, the motors are locked as soon as i plug in the power . i thought that was a normal action, what could this be??? has anyone had this problem before? and im running 425's so i cant even budge them what might the prob be? Last edited by fusiontech357; 11-09-2009 at 09:27 PM. |
| ok so i have removed all wires from my set up and rewired them all of it looks good as to driver and motor manufactures spec. still no movement drom the motors but when i remove the cp- from the driver and jump it to the cw- on the driver the motor moves a bit . the motor is locked soon as i but the wire back in to cp- of the driver.... |
| You either have the port address wrong, or the ports and pins settings wrong, or a bad cable.
| [IMG][IMG] [/IMG][/IMG]the ebay store is verycnc and its a db25 (bob) i set the external e-stop and wired it briefly and it worked so i thought that the (bob) was in ok condition . i do however have a 25FT pport cable hooked up to is , but again the input of the e-stop lead me to believe that the (bob) id good.. p.s the pinouts correspond to the motors inputs i feel i set them up right , then again , they might not be. the motors are set as follows X=cp-to pin2 cw-to pin3 ....Y= cp-to pin4 cw-to pin5 Z=cp-to pin6 cw- to pin 7 and i set that on mach 3 as well as on the (bob) Last edited by fusiontech357; 11-10-2009 at 09:04 PM. |
| found this thread regarding the c10 bob, it may help you: http://www.cnczone.com/forums/showthread.php?t=77423 Pablo
__________________ ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ● |
#10
| thanks pablo ive seen the thread i dont have the same setup i think. i was lookin at my printer port driver info and i have 3 differant options i have no clue what it means , ima try to pic it so someone might know what it means. |
| SX3 - Mach3 - non standard pin config - no movement... | krazatchu | Mach Software (ArtSoft software) | 0 | 11-23-2007 10:45 PM |
| NO movement, Any suggestions for my gecko 201 and Mach3 setup? | journeyonline | Machines running Mach Software | 1 | 11-15-2007 03:45 PM |
| Sporadic axis/motor movement suddenly started in Mach3! | boothie | Mach Mill | 2 | 08-20-2007 06:21 PM |
| mach3 and gecko vampire lack of movement | ged | Mach Software (ArtSoft software) | 9 | 03-18-2007 05:05 PM |
| Loaded or unloaded balls? | CNCadmin | General Metal Working Machines | 4 | 04-01-2003 01:41 PM |
