Old 03-19-2005, 11:21 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
No Z up on move
I see a bug with Mach 2, if you let's say stop the program(meaning g code program) with the bit still in the work and hit rewind and than hit play. Instead of Mach moving the Z Axis to a safe distance above the work it just does a rapid move and moves X,Y,Z all at the same time. Now if the Z has a slower acceleration than the other axis it will be a bit breaker.
To me Mach should always Z up before doing a rapid move, now maybe all I have stated would not be the case if using switches, but I have not trusted that out yet. One on version their was a problem with drilling and the bit not being clear before rapid moving, but that has since been fixed.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 03-20-2005, 12:11 AM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
Not overly familure with mach2 yet (still learning) but on most commercial CNC machines the machine only does what its programmed to do. So if your rewinding (I assume to the begining of program) The machine dosn't know and dosn't care what is between it and the move to coordinates it just moves.... so YES it is a bit breaker! ask me how I know
Michael t.
Old 03-20-2005, 07:39 AM
Mac T. Knife is on a distinguished road
Are you using Mach2, or Mach3??? I think that problem was addressed in Mach3
Old 03-20-2005, 10:19 AM
CNCadmin's Avatar
Site Owner
I'm using Mach 2.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 03-20-2005, 12:08 PM
WayneHill's Avatar
WayneHill is on a distinguished road
Talking
Originally Posted by miljnor
... The machine dosn't know and dosn't care what is between it and the move to coordinates it just moves...
CNC Error ?
Yep, CNC are not that smart. Don't know how many tools I've broken because the CNC didn't know better than the programmer/opertor...
The X-Axles... to move or not to move! Wild4aces Mechanical Calculations/Engineering Design 1 03-18-2005 01:26 PM
Speed how fast an axis can move? jlagran he General CNC (Mill and Lathe) Control Software (NC) 0 01-04-2005 10:05 PM
how does mach 2 and similar programs know how far to move ? Apples General CAM Discussion 1 05-11-2004 02:43 AM
Compensating after stopping a move wjbzone TurboCNC 1 05-18-2003 10:45 AM
User coordinate system? HuFlungDung OneCNC 5 04-18-2003 09:26 PM
