Old 03-19-2005, 07:27 AM
carlnpa is on a distinguished road
Need help extra lines in dxf
Attached is a drawing created in turbocad professional version 9. When I try to load into either sheetcam or mach2 many extra radius lines are shown. The same problem appears as dwg format. What am I doing wrong?
Old 03-19-2005, 07:43 AM
DAB_Design is on a distinguished road
Correct me if I'm wrong here, but importing a 3d dxf file into Mach2 won't work, will it?
Old 03-19-2005, 08:44 AM
ger21's Avatar
No it won't work. What youre seeing is that the object is a mesh, made up of many triangles and 4 sides flat surfaces. Mach2 will only read simple 2D entities. Lines, arcs,....
If your using sheetcam, try just drawing your border and 4 circles, and set up the pocketing in Sheetcam. Mach2 won't create the pockets, you'll have to draw all the toolpaths to clean out the pockets if you use Mach2's conversion.
Old 03-19-2005, 03:48 PM
Thank you for the replies. Part of what confused me about the mach conversion was that it at least imported the 3D dxf file and put it in the editor. Your guidance to use sheetcam on 2D dxf with pocketing works fine.
G-Code to DXF WayneHill OpenSource Software 200 04-22-2012 09:51 PM
Dirction / Step lines! bigal TurboCNC 2 02-06-2005 01:51 PM
DXF Catalog CNCdude Product Announcements & Manufacturer News 2 08-26-2004 09:07 PM
DXF files mmjpotter General CAM Discussion 2 09-18-2003 11:51 AM
