| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
quick background; I purchased one of these zero setters; http://cgi.ebay.com/ws/eBayISAPI.dll...m=270446538093 It works fine by itself, but I decided to put on a lug to attach an aligator clip to and use Mach3's index input for automatic Z zero setting. That worked fine on my old eMachine 600mhz computer. Then I upgraded to a newer computer, a dell 2.8ghz Dual core. The computer itself works fine with Mach3. And on the diagnostic screen the above setup indicates good index signal. But, when I try to use the Z depth auto probing, it almost immediately detects a closed circuit, even though the Z barely moves. A little DVM check shows that the zero depth block is not really open, it shows a 300k resistance - but like I said it worked with the older computer. So it seems the parallel port electronics are a little different between the computers. The question is; will a simple pull up resistor correct this problem? I'm not a wiz at electronics, but it would seem contrary to me. What would be a good value to try? |
| Do you have a breakout board? It should have pullups. Try using the DVM to measure voltage on the block, if it doesn't pop up to near 5V when open then try adding a 1 to 5k pull-up resistor. If its quickly detecting a closed circuit on z-probe, but not staying on, it could be due to noise. |
| Tags |
| index, mach3, z depth |
| current set resistor question | m8kingit | Gecko Drives | 8 | 03-20-2009 08:00 AM |
| G540 resistor question | LaserImage | Gecko Drives | 2 | 12-01-2008 11:54 AM |
| Gecko 540 and Resistor question | SpeedsCustom | Gecko Drives | 7 | 11-30-2008 09:39 AM |
| Braking resistor question | Syp | Servo Motors and Drives | 4 | 01-20-2006 09:52 PM |
| resistor question | plast744 | General Electronics Discussion | 8 | 07-10-2005 02:20 PM |
