Old 10-27-2009, 11:02 AM
86meesta2 is on a distinguished road
Catia v5 to Mach 2
I am using catia v5 to do my part designing/toolpath generation, and I am using Mach 2 with my machine. I used the import .jpg/.bmp feature in Mach 2 last night to play around, and I actually cut out a few things successsfully. However, I had a part I used catia to generate the g code with, and when I loaded it, it is in a completely different format:
Mach 2 created this for the image I cut out:
M3
G0 X0.000 Y0.000 Z0.000
G1 X0.000 Y0.000 Z-0.996
G1 X0.100 Y0.000 Z-0.996
G1 X0.200 Y0.000 Z-0.996
G1 X0.300 Y0.000 Z-0.996
G1 X0.400 Y0.000 Z-0.996
G1 X0.500 Y0.000 Z-0.996
G1 X0.600 Y0.000 Z-0.996
....etc
Catia outputs this for the part I want to cut out:
GOTO / 2.71116, 2.39813, 1.14764
GOTO / 2.71116, 2.39813, 0.75394
GOTO / 2.32327, 2.39813, 0.65000
FEDRAT/ 1000.0000,MMPM
GOTO / 2.32187, 2.39813, 0.65000
GOTO / 2.32187, 2.33187, 0.65000
GOTO / 4.14813, 2.33187, 0.65000
GOTO / 4.14813, 2.39813, 0.65000
GOTO / 2.32327, 2.42938, 0.65000
GOTO / 2.32327, 2.46063, 0.65000
GOTO / 2.25937, 2.46063, 0.65000
GOTO / 2.25937, 2.26937, 0.65000
GOTO / 4.21063, 2.26937, 0.65000
...etc
How do I make catia output code Mach 2 can read?
Thanks!
Old 11-02-2009, 06:12 AM
Mstcnc is on a distinguished road
M3
....etc
...etc
Thanks!
What you have output is APT code not G-code.
You need choose postprocessor from "options" menu.
I would think IMS has good Fanuc post which is compatible with Mach.
After defining post you need choseŽoutput type as g-gode, not apt.
Regards Mika
catia Rich05 General CAD Discussion 1 10-10-2008 05:07 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
catia NC output with mach 2 cnc? hpghost General CNC (Mill and Lathe) Control Software (NC) 5 09-02-2006 12:22 AM
What is Catia CNCadmin General CAM Discussion 20 05-20-2005 04:17 PM
Catia whiteriver General CAM Discussion 5 07-02-2004 12:14 PM
