Old 10-24-2009, 05:53 PM
Rhino3Master is on a distinguished road
Mach3 keyboard commands???
Hi there, I will be glad if someone could help me figure out the following "problems":
1. Is there any list where I can check the default keyboard commands of Mach3? I want to assign some of them directly to my GamePad. First lesson already learned - F10 and F11 keys is a priceless feature on your remote control (GamePad)
2. Is it possible to assign one key for lets say 50% feed rate, another key for 100% rate and 3rd key for 250% rate? I know about the Jog mode override function BUT I need something that gives me at least 2 alternative speeds while my CNC-milling machine is working on my foam parts.
Thanks,
Bobi
Old 10-24-2009, 10:30 PM
TOTALLYRC is on a distinguished road
If you are assigning them in key grabber it may take a little looking but it shouldn't be too tough to figure out.
I am not sure on the second part. I think it is possible but I am not in front of my Mach3 computer at the moment to check it out.
Mike
Old 10-24-2009, 10:58 PM
ger21's Avatar
1) http://www.machsupport.com/forum/ind...c,11463.0.html
2) You could do it be creating 3 custom buttons on the screen, each with a VB macro to set the override %. Then just assign Hotkeys to those buttons.
Old 10-28-2009, 03:21 AM
Thank you for the help, guys! I will try the methods you described and see whether it will work for me. Looks like creating custom buttons is the best way for my purpose.
I don't know why the RESET command (software E-stop) is not assigned by default to the Esc key since it's probably the most important button in Mach3.
Arc commands on GE1050HLX MetLHead G-Code Programing 3 07-16-2008 07:47 AM
Keyboard shortcuts for jog commands? hindocarina Mach Mill 6 06-14-2007 09:29 PM
G2 and G3 Commands Bohemund G-Code Programing 19 05-28-2007 09:12 AM
Difference between BL and SV commands? Shizzlemah Fadal 3 03-23-2007 08:33 AM
EMC & the G28/G30 Home commands Javelin276 LinuxCNC (formerly EMC2) 1 07-18-2005 03:13 PM
