Old 10-12-2009, 05:36 AM
cjchands is on a distinguished road
* 0-5V output to match 0-10V input inverter
Hi guys.
I am wondering if you can suggest the best simple circuit to get my breakout board output 0-5V analog to match inverter input 0-10V input.
I am testing this no name breakout board and I couldn't get more than 5.5V at maximum 25000 RPM in mach 3 program.
M5 = 0V
Max 25000 RPM = 5.5V.
Any advice how to build simple circuit for this?
Appreciate any advice.
Thank you
Jeff
Old 10-12-2009, 05:43 AM
Just to clarify.
I get
M5 = 0V
10000 RPM = 2v
25000 rpm = 5.5v
So circuit that proportionally give out double voltage value to get 0-10V to inverter input.
Thank you
Old 10-12-2009, 10:40 PM
Torchhead is on a distinguished road
OP amp circuit (non-inverting) that has about a 2X gain. You can put in a pot and make it adjustable. You will need to supply the Op amp V++ and Gnd with 12VDC to get the ful range to 10V. Conventional op amps acan only swing to with in about 1.2 V of the positive rail. A doubler has to have some form of AC (pulsing DC ) and it's pretty non-linear so your accuracy would go out the window. Simplest non-inverting adjuatable circuit is a single supply part (LM358, LM324, Tl082, etc) . Tie the + input to the voltage you need to scale. tie the output through a 10K pot to ground (each end of the pot). Tie the - input the the pot wiper (center). Instant non-inverting amplifier!
TOM Caudle
www.CandCNC.com
Old 10-13-2009, 09:05 PM
arturod is on a distinguished road
Jeff,
Maybe this circuit will do the job for you: http://www.cnc4pc.com/Store/osc/prod...products_id=61.
Keep in mind it is not optoisolated, so your VFD should have an optoisolated analog input, or you should optoisolate the 0-5vdc.
Arturo Duncan
http://cnc4pc.com
Old 10-14-2009, 01:30 AM
Thanks Duncan.
Fortunately, I have C16 from CNC4pc board, so instead of using 0-5Vdc output from noname breakout board.. I will use one of the remaining output step and direction to get 0-10V output.
Appreciate your advice though....thank you very much.
Jeff
Need Help!- Send/receive program without output/input push padobranac Fanuc 12 10-20-2010 09:53 AM
Need Help!- Input/output signal on 0M-C padobranac Fanuc 3 10-28-2008 09:49 AM
program input/output with RS232 port on Mitsubishi 50L Chuck Reamer Mazak, Mitsubishi, Mazatrol 3 02-04-2008 02:56 PM
Parallel pin 01 - E-stop use as Input or output? mike944 LinuxCNC (formerly EMC2) 2 12-03-2007 08:39 AM
Is this Input or output voltage Mr.Chips Xylotex 8 01-24-2007 09:36 AM
