Old 10-11-2009, 10:46 AM
krummigudna is on a distinguished road
step/direction to +/- 10v (analog)converter
Hello everyone.
I am looking for plans and drawings to built
a step/direction to +/- 10v (analog) converter for controling
my 3phase spindle drive(VFD) with MACH3.
I was told that SKYKO had this but not any more.
So im thinking to build me one.
Can someone help me with this.
Thank you.
KRUMMI
Old 10-11-2009, 11:06 AM
Al_The_Man's Avatar
I believe you want PWM to ±10vdc, last time I checked the spindle was controlled this way.
Old 10-11-2009, 12:06 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
At $38, is it worth doing it yourself?
http://homanndesigns.com/store/index...c602191e6fa87c
Regards,
Mark
www.wrathall.com
Old 10-11-2009, 12:14 PM
H.O H.O is offline
H.O is on a distinguished road
The Skyko product you mentioned was for controling analog servo-amps with encoder feedback back to the Skyko card, ie for closed loop servomotion.
Mach3 can control a spindle either thru step and direction or low frequency PWM. The LM2907 is a frequency to voltage converter chip that can be used to convert the step-pulses to an analog voltage. I'm attaching a schematic of how I did mine a couple of years ago.
Old 10-11-2009, 02:45 PM
jjobezo is on a distinguished road
British option
I have used boards from this site with good results. This controller includes a relay for reversing direction.
http://diycnc.co.uk/html/spindle_2.html
Old 10-11-2009, 03:31 PM
johnmac's Avatar
johnmac is on a distinguished road
www.cnc4pc.com may have what you are looking for.
John
Old 10-11-2009, 07:52 PM
Torchhead is on a distinguished road
Originally Posted by krummigudna View Post
Hello everyone.
Thank you.
KRUMMI
You migth want to check your VFD specs again. Most use 0 to +10VDC (unipolar) for 0 to max RPM. I have not seen one (VFD) that uses negative voltage for speed control. + & - 10 are used in older servo drives to do both speed (velocity) and direction with one signal. The Skyko was made for that usage but the demand is low for analog only servo drives running from S & D. There are alot of spindle speed 0-10VDC solutions. Try to determine what you need and if it needs to be isolated. Some VFD's internal electronics are not isolated from the AC lines and can really mess up anything connected back to the PC logic side. Lots of noise in VFD's too...another good reason for isolation.
TOM Caudle
www.CandCNC.com
Old 10-14-2009, 08:27 AM
Hello everyone.
Tom, you are right this is controled like you pointed out.
There is a diffrent signal for changeing direction.
Just a shortcircuit in my head.
Thank you for your time and effort to help me.
Krummi
Old 10-14-2009, 08:45 AM
You are right Al it can be controlled this way (and maybe it is a better way).
According to the MACH 3 turn manual it can also be controled with step/direction.
I have not tried it so i dont know if it works.
Do you think PWM is a better way ?
Krummi
Old 10-14-2009, 09:21 AM
Good tip jjobezo
but i am not sure the British want anything to do with ICELANDERS right now
..............hahahahaha
Krummi
  #11   Ban this user!
Old 10-14-2009, 09:30 AM
Originally Posted by H.O View Post
Your answer and drawings were very helpful H.O
Krummi
  #12   Ban this user!
Old 10-14-2009, 09:39 AM
Good point, but im the (built everything myself type)
......hahahahaha....
Krummi
PWM&direction into voltage converter visky Want To Buy...Need help! 0 04-05-2009 11:47 AM
Step and Direction to Analog gdb General Electronics Discussion 6 11-14-2007 10:19 PM
Convert +- Analog to Step & Direction ??? Argofanatic Servo Motors and Drives 1 01-20-2007 03:47 PM
Pixie Step/Dir to Analog Servo Controllers KTP Product Announcements & Manufacturer News 0 03-06-2006 10:12 AM
Step/Dir to Analog converter? DennisCNC Servo Motors and Drives 3 12-19-2005 05:05 AM
