Old 10-09-2009, 08:45 AM
groomden is on a distinguished road
how to slow down z jog rate when manually zeroing
hi,
it seems like this was really easy a couple months ago when i last did this but...
i am trying to slow my z down so that i can manually lower my router bit to set a z-zero height. i've tried the feed override button/slider thing and it doesn't affect how fast my z is moving up/down at all. it seems to default to having a six in the box but not sure why... this problem is persistent wether or not i have a g-code file loaded or not.
help! i don't want to slam my bits into my workpiece while setting up!
thanks for any ideas:-)
Old 10-09-2009, 10:31 AM
ger21's Avatar
Hit tab and change the slow jog %.
What I do, is jog close, then switch to incremental set to .002.
Old 10-09-2009, 11:55 AM
cool, thanks
Need Help!- Control Plunge rate & Retract rate GEORGETOUBALIS G-Code Programing 8 04-13-2009 06:12 AM
Need Help!- Feed rate Ovverride also Increases rapid rate. Korellibopper Machines running Mach Software 1 01-30-2008 05:37 PM
Using G01 alongside G00 (slow feed rate woes) inthezone FeatureCAM CAD/CAM 4 07-31-2007 10:36 PM
O mate M slow rapid rate Phase II diemaker Fanuc 0 10-18-2006 04:08 AM
O mate M slow rapid rate diemaker Fanuc 6 10-09-2006 02:14 PM
