| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Hi All, sorry if i have posted in the wrong area Just having an issue with either the calibration or gcode, Basically went through the calibration setup of each axis and tested it by inputing code into the directly into the MDI window and cutting a 150 by 150 box with a 6.35mm cutter. from this the calibration appeared correct. (-/+ .05) Next i tried to cut a 150mm box with gcode from mastercam: N720 Z6. N730 G01 Z0. N740 X146.825 N750 Y146.825 N760 X3.175 N770 Y3.175 N780 G00 Z26" but after i measured it it was out by .65 on the y axis and .5 on the x axis, which seems strange it would be out as clearly the above code says both X&Y are the same?! hence why i'm not sure if this is a MC issue or M3? Any thoughts or advice would be greatly appreciated! Cheers Lappy |
| From what you show, it should cut the same in X or Y. You may need to fine tune your steps per inch. Feedrates can also effect size errors, especially on less than rigid machines. Backlash can also cause this.
| Need Help!- Mach 3 GCode Error | stabbs | Mach Software (ArtSoft software) | 2 | 08-21-2009 01:02 PM |
| Need Help!- Axis calibration? | saabaero | Tormach PCNC | 16 | 06-23-2009 08:54 AM |
| Newbie- Calibration | metalfixer | CNC Plasma and Waterjet Machines | 5 | 12-22-2008 04:27 AM |
| I have a problem with my gcode or my conversion to gcode , everything is tiny? | NickLatech | G-Code Programing | 0 | 03-10-2005 12:46 PM |
| gcode to gcode converter | july_favre | General CAM Discussion | 4 | 05-24-2004 06:51 PM |
