| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
Hi again everyone. I am very struggle with charge pump connection and hope if someone can help clarify. I use the break out board and set up Pin 17 (Low Enable) to use as charge pump which connect directly to the Solid state Relay (3-30Vdc). I do get 3.2 Vdc when software is running. 0Vdc when is not. Solid state Relay connects to Magnetic Switch Coil (110V) which intended to cut off power to Driver. Problem now is that when I actually connect the other end of Solid State Relay 110V to Magnetic Switch Coil (110V)....It keeps flipping ON / OFF /On /OFF. Vice versa-- When I set to HIGH..it did the same thing. Any help is appreciated? Jeff |
Hope this helps. debetto |
| Debetto. Standard Parallel connect to the breakout board. I have Pin 17 (output from the breakout board) and V+ connects to Solid State Relay (+3v-30Vdc). Relay Turn on when programing running. (Measuring +3.2V) Relay Turn off when program stops. (Measureing +0v) Up to this point...everything seem to be ok!! HOWEVER....When I put load on the other end of solid state relay (110Vac this case) to shut off magnetic switch (POWER to the drive)... It flips on/off/on/off..... What do you think happen? thanks Jeff |
| What is the part number of the SSR you are using? What is the exact nature of the load you are switching with the SSR? Put 5v directly on the input if the output stays on, this eliminates the SSR and the load and the problem would point to the nature of the input signal. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 09-24-2009 at 10:07 AM. |
| Hello Everyone. Thanks for feedback. I got it working now!! Have P17 and +V connect to Solid State Relay to shut off Power Supply to the Drive Directly. Which mean 3 axis..I need each separate Solid State Relays. What I don't understand though is this.... I am trying to do the same exact thing, but instead of connect my other end of solid state relay to each power AC to the drive, I try to shut off Only one Magnetic Switch that connect to all axis AC power(just so I don't need 3 separate solid state relays). Problem then is the Magnetic Switch keeps turning ON/OFF/ON/OFF....like crazy. Any idea why this problem happen?? Thank you Jeff C. |
| You still did not identify the components you are using? The SSR and the Relay part number? Also did you do the 5v test directly? Where are you controlling the AC to the drive? Are they all fed from one transformer or power supply? Al.
| What is the manufacture and P/N of the magnetic switch?
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| Hi Again guys.. Here is the information: Solid State Relay SSR-10DA, Input 3-30Vdc, Output 380Vac (brand: Salser) Magnetic Switch SRC 3631-5-1, coil 100V (brand: Fuji) Relay 1315-4c, 5A 30Vdc (brand: Kolke, Guardian) (current setup: Charge pump -- Solid State Relay -- Direct Power to Driver (220Vac) I measure 3Vdc (pin 17, V+) when MACH 3 is ok. -2Vdc when MACH 3 is in emergency mode. +4.8V when PC shut down Thanks for feedback. Jeff. |
| I believe what is happening is that when you shut the 120vac off with the relay you are also dropping your coil voltage out, this would cause what you are describing. Al.
#10
| Sounds like you don't have an issue with the charge pump driving the SSR because of the one configuration working. If I read your post correct, you said you had problems regardless of the state of the charge pump, hi or low. Can you scetch up a schematic of how you were wiring the ssr output, magnetic switch, relay and loads?
#11
| Thanks again for more feedback. I have attached my wiring diagram.. This is my first time ever use the software to draw. I actually spent good half a day drawing this ![]() Due to lack of knowing for all the symbols..hopefully you guys understand it. Please comment. I currently have only 1 charge pump on 1 test axis...and look like it does work. I am planning to put separate solid state relay on each axis. But connect all input to P17 and V+. So hopefully they all turn off when it should be. Thank you. |
#12
| There are a few things that do not add up with the dwg. Maybe due to the incorrect drawing of the symbol? For example, you show the 3 phase isolation transformer for the drives and it does not show a transformer star connection for the drive return? You have shown a ground symbol for the return of what I take is the star point of the feeder transformer. Hopefully this is a mistake in showing what should be a star point set up as a neutral? You should never use the ground as a conductor, even though the neutral is actually at ground potential. IOW, all the points you show with a Earth ground symbol should be a neutral conductor. The Earth ground symbol used at the drives, implies that the commons of the 3 drives are at the same potential as the 380v common point. I do not see the SSR in the dwg, only the contact depiction to the drives. I would have used a 380/120v transformer for local 120vac supply, one side of the secondary could be set up as a local grounded neutral. The E-stop would have dropped out the main 3 phase contactor which would be on the drive side of any auxiliary supplies, 120vac, 24vdc etc, these would remain live in the case of an E-stop. All commons and neutrals etc would go to a central Earth ground point, that should be at actual ground potential. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 09-27-2009 at 09:37 AM. |
| Charge Pump | cadmonkey | LinuxCNC (formerly EMC2) | 8 | 04-06-2010 01:19 AM |
| charge pump | eloid | DIY-CNC Router Table Machines | 3 | 01-25-2009 09:14 AM |
| Charge pump for Hilbilly BOB | dougputt | Mach Software (ArtSoft software) | 2 | 10-11-2007 12:31 PM |
| Charge Pump ??? | jack55 | General Electronics Discussion | 6 | 04-21-2007 02:59 PM |
| Charge pump | mlaws1172 | Screen Layouts, Post Processors & Misc | 0 | 01-03-2006 10:46 PM |
