Old 09-22-2009, 01:16 AM
mrpeja is on a distinguished road
Cool Mach3 weird behaviour
After four month normal working, my plasma table get weird. (I have THC also.)
Cutting holes seems normal, but when it cuts straight lines, after about 10, 20... sec torch begins to raise slowly until arc gets off. During this time, led DOWN on THC is on, and torch goes UP!
Any idea what causes this?
How to diagnose where is the problem?
mrpeja
Old 09-23-2009, 11:48 AM
I solved the problem!
I have set max THC to 10 mm and min THC to 1 mm. But the sheet wasn't flat and when the torch references to higher area, and later comes to lower area, it can't go below 1 mm. When I set min THC to -5 mm, all is OK.
So, the torch wasn't go slowly up, as I think. It can't go lower and torch voltage raises during lower parts of sheet, until arc go off.
BTW, I made test adaptor to simulate plasma equipment (Arc good and Arc led ON). The purpose was to test THC according to THC300 manual, without using clips connected to PCB. At the first time the torch won't go up and down, until I shut off AntiDive button.
I'm not sure if I need Antidive to be on or off.
Please advice about AntiDive.
P.S. excuse for my English
mrpeja
Mach3 Strange behaviour wellbuiltcabs Mach Software (ArtSoft software) 3 01-30-2008 07:48 PM
Strange behaviour of 10T guhl Fanuc 1 12-11-2007 09:28 AM
mach3 running xylotex 3axis weird problem Claude Boudreau Xylotex 6 07-18-2007 05:24 PM
VMC 15-XT strange behaviour FinnCNC Fadal 0 03-27-2007 11:03 AM
