| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I got my Bridgeport Boss Hillbilly BOB retrofit going with Mach3, but before I start cutting metal, I would like to have a knob-controlled feedrate override. I used that as a safety device with the Boss controller, and I hate to give it up. I've been playing around with a USB gameport adapter, keygrabber, and a potentiometer. XP will calibrate the potentiometer, but the problem is that Mach3 doesn't seem to pay any attention to the calibration. The effect on FRO only seems to be dependent on the potentiometer maximum resistance. Higher values give more effect on FRO, and lower ones less. Does anybody know anything about this? Incidentally, in case it makes any difference, I'm using an Thinkpad 770e, with ACPI turned off. It drives the system very well. I've played around with the USB adapter and pot on other computers, and it doesn't seem to be any better. |
It sounds to me like you have the pot not wired correctly. To get a variable voltage connect the "top" of the pot to a supply, the "bottom" to 0 volts (ground) and the wiper to the analogue input. I had loads of problems with Mach3 on XP - mainky missing Z commands and crashing the work and sometimes the tool too. Since I switched over to linux emc2 no problems - and it has the feedrate overrride on the panel. Try linuxcnc.org Best of all it is FREE! |
Thanks for the replies. I looked at the Pokey device, and it looks very nice. However, the idea of having to buy an $80 device in order to do one simple thing does not appeal to me. I may wind up spending much more than that trying to figure this problem out, but it will be a learning experience. Perhaps I will build my own 'Pokey', using a PIC microcontroller. I just got some 40-pin 18F4550's ($4.40 at Newark), which have all kinds of analog and digital inputs, and a built-in USB interface. As to the pot connections, strange as it may seem, the pots are not connected to ground. The wiper goes to the input, one side goes to +5, and that's it. The pot resistance is read by the length of time it takes a capacitor to charge up. There's no ADC. Check around at all the info on joystick/gameport interfacing, and you'll see that. I did try hooking up one side to ground, and it still worked, but the results were very strange. I think this problem is either with Keygrabber, or Mach3. It would be nice if keygrabber actually showed analog input levels, instead of just indicating which input is being exercised. I suppose I should try the joystick plugin, to see if that works any better. Last edited by dynamotive; 09-21-2009 at 04:11 PM. |
Ok, I made a little progress. I got my single potentiometer hooked up so that FRO consistently moves smoothly up and down. The problem is, FRO goes from near zero to 10 times the feedrate value that is showing. Mach3 starts up with 6.000 for the feedrate, and when I turn the pot, FRO goes from about .15 to almost 60. In other words, a maximum feed rate override of 1000%! I tried different pots, and re-calibrated it in XP several times, but it always acts the same. Is there some configuration setting that controls FRO versus feedrate? |
| I t shouldn't be able to do that. The maximum FRO is controlled by the screen file. I believe it's set at 200% in the default screen. The FRO DRO is percent override, so 60 is 60%, for a feedrate of 9.6ipm. That's what you should be seeing in the velocity DRO.
Thanks for the reply. So are you saying the Feed Rate Override goes from zero override (no override), to 60% override? I don't want to speed up the feed, I want to slow it down, all the way to no feed, sometimes. Is there any way to do that? I don't want to stop and start the feed, I want to be able to slow it down! |
| No, I said that wrong. Typically it starts at 100%, and goes down to 0% and up to 200%. 100% is the commanded feedrate.
Ok, this is how it works: If I turn the pot to zero, the green FRO bar goes to zero, and the FRO percentage and value go to (almost) zero. When I start to turn the pot up, the bar quickly goes to 1/2 height, the FRO percentage goes to 100%, and the FRO value to 6.000 (the default feedrate). A little more turning, and the bar goes to full height, the FRO percentage goes to 200%, and the FRO value goes to 12. More turning, and the bar gets taller, and covers up the FRO percentage value. More turning, and the FRO value keeps climbing, all the way up to almost 60. Like I said, 1000% override. All the useful stuff is taking place in 1/10 of the pot's travel. Is there any way I can change the maximum allowed override value? |
#10
| Change the DRO format with Screen4, mach's screen designer. But, it should be set to 200, maybe 300 max by default. Are you sure it's going to 1000, and not just to 300%?
#11
Is Screen4 the only way to change the maximum override value? Thanks for the help. |
#12
| Do a Print Scr - on your keyboard (screenshot) of what your Mach3 screen looks like. Then post the screenshot/image here on the forum. Might help with the answers, to your ?'s
__________________ Free DXF Files - Vectorink.com - myDXF.blogspot.com |
| Need Help!- Fadal 6030 CNC88 Feedrate Override Inactive (fixed at 100%) | hascoservices | Fadal | 8 | 07-29-2009 10:40 AM |
| Feedrate override with MPG | foka4 | Mach Wizards, Macros, & Addons | 1 | 07-04-2009 04:08 PM |
| Feedrate Override by Keyboard | Tazzer | AjaxCNC Control Products | 1 | 03-26-2007 01:16 AM |
| Does Mach3 tool diameter override gcode setting? | WarrenW | Mach Software (ArtSoft software) | 1 | 04-27-2006 08:09 AM |
| Feedrate Override | JFettig | TurboCNC | 2 | 12-09-2004 06:17 PM |
