Old 09-19-2009, 05:35 AM
cjchands is on a distinguished road
** (NEWBIE) How to activate assigned OUTPUT signal **
Sorry for being so newbie..
I got 3 axis MACH working previously, got LIM working properly.
But Never done the output before..
I set Enable #1, Output #1 activated. Assigned Pin # 16
I see diagnosis page with Enable #1 on.
But how exactly do I program or activate in the software to send my output out?? Can't seem to find description in the manual either.
Similarly, even more simpler.....I want to turn on Coolant M7, M8, M9.
But I don't see in the set up pin # where to connect COOLANT pump on.
Please advised instruction...
Thank you very much in advanced.
Jeff
Old 09-19-2009, 05:36 AM
Hopefully..doesn't have to do anything with Macro yet?
Old 09-19-2009, 06:43 AM
ger21's Avatar
You shouldn't need to set the Enable for an Output.
Assign Pin16 to Output 1. Go to the Spindle tab of Ports and Pins, and assign Output 1 for either Mist or Flood, and make sure the Disable coolant box is NOT checked. That should do it. M7 or M8 will turn it on (depending on which you choose), M9 will turn it off.
Old 09-19-2009, 06:45 AM
ger21's Avatar
Do you want to send an Output for something other than the coolant? What exactly do you want to do?
Need Help!- Input/output signal on 0M-C padobranac Fanuc 3 10-28-2008 09:49 AM
No Output Signal tz1238 Machines running Mach Software 1 01-27-2008 02:57 PM
can I output square waves for step signal? mike944 LinuxCNC (formerly EMC2) 5 12-31-2007 07:27 AM
Diag: Output Signal: Enable 1 help... Flatline's Up! Syil Products 11 04-06-2007 02:11 AM
*WORK ASSIGNED* RFQ 1 set of Router Mounts. Thazul Employment Opportunity 1 01-19-2006 04:27 PM
