Old 09-19-2009, 05:27 AM
cjchands is on a distinguished road
** Connection Charge Pump Frequency 15K Hz **
Please Help as I read in the previous post and still couldn't get the idea how to connect this.
I am using breakout board which already have +5V and Charge Pump ports.
I detect about 15Khz when I activate Pin 10 for charge pump.
But I don't know where do I connect this 2 ports too?
My initail thought is to connect this in serie/parallel with Emergency switch somehow and when MACH 3 have error..then it will be disable?
Please advised and help..as I try to put safety into the machine.
Thank you very much in advanced.
Jeff
Old 09-19-2009, 05:29 AM
Anyone with sample diagram..would help.
And i thought it is supposed to be constant 12Khz.
Why do I get 15Khz?
Old 09-19-2009, 06:50 AM
ger21's Avatar
What breakout board do you have.
Old 09-20-2009, 10:00 PM
Hello Gary
Thank you for quick kindly respond.
The board came from Oversea as shown in the picture.
I do not have any information on the schematic except it said
"P17 Pump electric charge pump may control a group solid state relay in view of MACH to output".
Please advised.. .
Old 09-21-2009, 06:08 AM
Hello Gary or any experience charge pump user.
My understanding about charge pump (Pin 17 setup) is that when frequency change for whatever reason, output go LOW.
Please comment my Wiring connection wise, I would use this function to turn on/off SOLID STATE RELAY which would enable/disable AC magnetic coil so my power source to the driver would SHUT OFF when something is wrong.
I also ADD "emergency button" in serie, so I can physically shut off.
(Please see my simple block diagram).
Am I understanding this right??
If so...then here is my curiousity.
When MACH 3 is running, I get 12Khz (0.5V) Pin 17 to GND
When MACH 3 is off, I get 13.5Khz (6.3V) Pin 17 to GND.
Is this sound like the right frequency number? Frequency doesn't stay constant...
Is my block diagram seem functional?
I am still a newbie..so any comment is appreciated.
Thank you
Jeff.
Old 09-21-2009, 06:15 AM
by the way,
Am i supposed to check this constant frequency
WHILE PROGRAM is RUNNING??
This charge pump suppose to work only when program is running?
Or can it just be simply MACH 3 on or off??
Charge Pump cadmonkey LinuxCNC (formerly EMC2) 8 04-06-2010 01:19 AM
charge pump eloid DIY-CNC Router Table Machines 3 01-25-2009 09:14 AM
Charge Pump ??? jack55 General Electronics Discussion 6 04-21-2007 02:59 PM
Charge Pump circuit raytor Machines running Mach Software 1 10-16-2006 04:23 PM
Charge pump mlaws1172 Screen Layouts, Post Processors & Misc 0 01-03-2006 10:46 PM
