Old 09-12-2009, 07:33 PM
Crawler374 is on a distinguished road
My steppers are not moving.
Hey everyone,I'm having trouble. I got everything wired up and on to my computer. I followed all instructions, and the tutorials on MAchsupport. But, My steppers are not doing anything. I have the hobbcnc 3axis kit if that helps.
My steppers are wired up correctly. But, I cant seem to get them to work. Any suggestions?
Old 09-12-2009, 07:35 PM
ger21's Avatar
Do they lock up when you power up the board?
Old 09-12-2009, 09:40 PM
No, nothing comes on. I got a volt meter and voltage is getting to the CNCboard, but no further. The CNCboard fan does not come on either.
Old 09-12-2009, 10:39 PM
ger21's Avatar
Then you have a problem with your HobbyCNC board.
Old 09-13-2009, 01:02 AM
Well, I was over looking everything, and noticed that one of my capacitors were not soldered in 100%. I got it soldered in, and now my board is reading voltage correctly.
But I'm still having stepper driving issues. It seems that Mach3 is not sending signals to the hobby board.
Old 09-13-2009, 08:51 AM
ger21's Avatar
If you jog or run code in Mach3, do the DRO's change. If they do, mach3 is sending signals. Then the problem is usually that the port address is set wrong, or the ports and pins settings are wrong, improper parallel cable,.....
When you say not sending signals, can you be more specific?
Old 09-13-2009, 10:53 AM
Thanks for the reply Gerry. I will test that out.
By not sending signals, I mean that Mach3 is not telling the HobbyBoard what to do.
Old 09-13-2009, 11:02 AM
ger21's Avatar
How are you sure of that?
Old 09-13-2009, 12:12 PM
I'm not. It seems as it is not sending signals.
Okay, so here is my update.
I have re-set all mach3 settings with no success.
I have my steppers wired correctly.
My board is reading 5.2v
My steppers DO NOT lock up
It appears as Mach3 is working, but how do i test it?
Old 09-13-2009, 01:30 PM
ger21's Avatar
If the steppers do not lock up, then the drives are not working. There is no power at the motors. It's not a mach3 problem.
  #11   Ban this user!
Old 09-13-2009, 01:31 PM
Well, look like i will be posting in the Hobbycnc section now.
thanks for the help Gerry.
Trade offs between Moving Gantry and Moving Table gregmary DIY-CNC Router Table Machines 11 04-22-2011 01:48 PM
Moving Table, or Moving Gantry? (For Router) Cryptonic26 DIY-CNC Router Table Machines 6 04-20-2011 02:38 AM
Need Help!- G540 problem, steppers not moving CS900 Gecko Drives 36 11-13-2008 10:38 AM
Discussion of moving table vs moving gantry rkremser DIY-CNC Router Table Machines 5 02-20-2008 03:59 PM
Moving Table vs Moving Gantry; Dremel vs Router chuckknigh DIY-CNC Router Table Machines 32 03-27-2007 08:48 PM
