| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I have my machine setup in inches using: - 1/2-10 ACME lead screws - 1.8 degree, 270oz steppers (200 steps per rev) - 1/8 microstepping drivers My motor tuning in Mach3 is Steps per Revolution = 20000 Velosity = 60 Acceleration = 1 Step Pulse= 5 Dir Pulse = 5 These values are from memory as I'm not in front of the router PC. My router is super smooth with these settings, I'm very happy with its operation. Now, I want to start using Metric units and I do not want to mess with my Imperial setup, will Mach3 allow me to create another profile with different motor tuning? As well what would the settings be for my motor tuning for me to setup metric. I have to convert the 10TPI screw to metric (turns per mm or cm) I do not think there will be many turns per mm. Thanks for the help. |
| In your current setting, the steps per unit should be 16000. To set it up in mm, it would be 16000/25.4 = 629.921 steps/mm Yes, you can have multiple profiles set up.
| It worked fine. I did have my drivers at 1/10 stepping. I set my metric profile at 20000/25.4 = 787.401574 Thanks for the help. Now I need to fix the AutoZero Setter to work in both profiles. Maybe I can make 2 custom files and set the custom button script per file... |
| stock profiles | kendo | EdgeCam | 6 | 02-09-2009 08:59 PM |
| Z-Profiles | mrcodewiz | Dolphin CADCAM | 13 | 05-16-2008 07:22 PM |
| Rail profiles? | sp1nm0nkey | Linear and Rotary Motion | 3 | 02-04-2008 12:11 PM |
| plasma profiles | trevorhinze | CNC Plasma and Waterjet Machines | 12 | 01-24-2006 11:14 AM |
| Profiles for CNC lathe | Don C | Mini Lathe | 5 | 04-24-2005 07:17 PM |
