| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
My homebuilt machine (router) using mach 3 runs choppy on arcs. When I set it to run on CV mode, my steppers stall. I,m only running the machine at 48ipm. Does anyone have any suggestions? Should I slow down my feed rates? I would like to double my feed rates but can't seem to work it out. Any suggestions on motor tunings? Running keling 425's with 24v PS. 1/2-10 Acme's. Thanks, Jeff |
| Turn off all CV options, both in General Config and on Settings page.
| But I think I want to run in CV mode. Won't that make my machine move smoother? Should I try to slow my feeds till it no longer stalls? Should I just leave it alone? I run some programs with a lot of curves. My feeds are set at 48 but the machine fluctuates between 4 and 18 through 90% of the cutting. Wouldn't this be a case of "slow down to go faster"? If I lowered my feeds to 30ipm with CV mode on, wouldn't it cut this in about 1/2 the time? Or, am I just confused? Also, what are the pro's and con's of CV mode please. Thanks, Jeff |
| Turn off the CV options, not CV mode. If you're not reaching the commanded feedrate, it's probably due to a low acceleration setting. What is your accel set at?
| Can you get them up to 8 or 9? You'll see much faster cut times. Even if you have to lower the velocity a bit.
| Need Help!- Mach3 CV settings vs. G-100 Plugin CV settings | Bfarn | Machines running Mach Software | 7 | 12-17-2008 10:45 AM |
| constant velocity help | shnitzel | Mach Software (ArtSoft software) | 1 | 01-03-2008 08:10 AM |
| Constant Velocity Mode CONSTANTLY DIES! | backlashphoenix | Mach Software (ArtSoft software) | 9 | 05-21-2007 06:52 AM |
| constant velocity and power settings in mach3 plasma cutting | Knut | CNC Plasma and Waterjet Machines | 4 | 09-27-2006 10:19 PM |
| PWM Vs constant current | JerryFlyGuy | General Electronics Discussion | 3 | 10-25-2005 04:48 PM |
