Old 08-31-2009, 05:59 PM
chrispare is on a distinguished road
noob needs help
im using mach3 and want to know how to compensate for a different size cutting bit,(say 5mm instead of 2)
i am using mach3 to import the dxf file and then creat gcode.
the dxf file is created for lasercutting and i want to use a cutting bit.
how do i do this??????????
Old 08-31-2009, 06:21 PM
warrenb is on a distinguished road
Assigning tool offsets
You will need to set up a tool offset using a G-code offset (g41 (left side offset) or g 42 (Right Side Offset)) then you simply use the tool offsets table in Mach 3 and assign the correct diameter.
So you can take your toolpath and you'll have a line that looks something like this.
g41 (left hand offset) d1 (tool 1 reference)
This is similar to the tool height offset. g43 (tool length offset negative) h1 (height of tool 1)
Now you have to make sure that you are cutting the correct direction so that you're on the correct side of the line and correct cutting method, climb cut or upcut.
I hope this helps. Here's a link for g-code definitions...
I don't make toolpaths with Mach3 but this is standard G-code programming.
Good Luck
http://en.wikipedia.org/wiki/G-code
Old 08-31-2009, 06:31 PM
yes i created toolpath useing mach3.
Old 08-31-2009, 06:32 PM
jalessi's Avatar
jalessi is on a distinguished road
Question
Have you defined your tools in the tool table?
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 08-31-2009, 06:39 PM
yes i have.
and i have tried and changed just about every number and anything that can be changed.
when i try it out it dosnt compensate for the bigger tool diameter.
Old 08-31-2009, 06:47 PM
Originally Posted by chrispare View Post
yes i have.
Send your g-code post and a screen shot of your tool table and I'm sure we here at cnczone can help you out.
Old 08-31-2009, 06:52 PM
warren sent you a pm
Old 08-31-2009, 08:52 PM
jalessi's Avatar
Question
What about G42
Old 08-31-2009, 09:02 PM
ger21's Avatar
You need to have a proper lead in move where the compensation is applied. POSt your code here so we can see it.
You can also use G41 P2.5 for a 5mm cutter.
Old 08-31-2009, 09:27 PM
jalessi's Avatar
Tools are numbered from 0 to 255.
The tool number is selected by the
T word in a part program or
entering the number in the T DRO.
Its offsets are only applied if they
are switched On by the Tool Offset
On/Off toggle button (or the
equivalent G43 and G49 in the part
program)
  #11   Ban this user!
Old 09-01-2009, 04:29 PM
here is a couple pics of my setup ,
i hope you can see and be able to help
Old 09-01-2009, 07:47 PM
ger21's Avatar
You can't just tell it the tool diameter and have it offset. You need to write proper g-code for using G41 or G42.
Another noob looking for help cuetipper Want To Buy...Need help! 4 01-14-2009 08:41 PM
Noob puppiesonacid PCB milling 2 07-09-2008 08:25 AM
yet another noob mastermoparman CNCzone Club House 2 09-18-2006 01:22 AM
yet another noob mastermoparman General Metal Working Machines 1 09-15-2006 06:24 AM
NooB Needs a little Help js11110 DIY-CNC Router Table Machines 3 03-20-2006 05:41 PM
