Old 08-30-2009, 09:30 AM
Deviant is on a distinguished road
Mach3 on Laptop without Parallel Port
I'd like to upgrade my current mach3 pc and crt monitor with something a little easier to manage.
I was thinking about getting one of the Dell mini 10's. Since the price looks good.
Unfortunately, they mini10 does not have a paralell port.
So, can I get a usb to parallel port adapater and be golden?
Or??
Old 08-30-2009, 09:33 AM
ger21's Avatar
No, you'd need to use a Smoothstepper from www.warp9td.com
Old 08-30-2009, 09:37 AM
TOTALLYRC is on a distinguished road
Or??
NO
A smooth stepper or other external motion controller will work but not a usb to parallel adapter.
Laptops with pports can be problematic anyway.
Get a used lcd and stash the tower under the desk if possible.
I do sympathize with the space constraints of a small work shop especially when you stuff 6 machines in a space designed for 2.
Mike
Old 08-30-2009, 09:49 AM
Ok
That's what I was thinking. I was just hopeful that someone would tell me that X adapter is powered externally and would work.
*mumbles*
Is anyone using the smoothstepper successfully? I've looked at those in the past and it seems to still be in it's infancy.
Old 08-30-2009, 10:00 AM
You can get a small form factor pc if space is an issue. Some still come with a pport or you can add in a pci card if needed. Just need to make sure you don"t have video issues.
Other people can tell you which one to get.
Mike
Old 08-30-2009, 10:11 AM
ger21's Avatar
If you don't need more than 25Khz, a Dell GX150 with a 1Ghz processor works great and are $10-$50 on Ebay.
Old 08-30-2009, 10:20 AM
Mostly I was looking at space. I wanted to mount the laptop on a little arm that is attached to the table.
Currently I have a ~2.5ghz machine with crt. I guess I'll replace the crt with a lcd, maybe a touch screen one.
I'm not quite stepping over myself, but when I have the car/motorcycle etc in the garage. It starts to get very cramped.
Old 08-30-2009, 10:59 AM
Wait until you start getting more machines in the garage.
You will need to put the car/motorcycle outside under a tarp.
Old 08-31-2009, 07:34 PM
carvemylog is on a distinguished road
I mounted one of thesehttp://cgi.ebay.com/Desktop-Table-LC...d=p3286.c0.m14 to one of the legs of my CNC and bolted a piece of plywood on the top of it. It holds a 22" LCD, keyboard, and mouse. A small Dell 2.7GHz PC sits on a shelf under the main CNC table. WHen I'm done, the LCD is removed and the whole arm rotates over the table. The CNC is on casters so I can roll it out of the way.
PCMCIA Parallel Port on Laptop Jim Estes Controller & Computer Solutions 13 09-29-2009 10:38 AM
Need Help!- Mach3 Not Working At All With Parallel PCI Port Brenck Mach Software (ArtSoft software) 3 07-14-2009 07:43 PM
laptop usb parallel port dgalaxy General Electronics Discussion 11 04-09-2008 04:00 PM
laptop pcmcia parallel port works craigtx Computers and Networking 0 12-12-2007 01:31 PM
Mach3 and Parallel port Me2 Mach Software (ArtSoft software) 4 01-28-2007 04:38 PM
