Old 08-15-2009, 10:52 PM
el_tony33's Avatar
el_tony33 is on a distinguished road
SETTING UP A SECOND SPINDLE IN MACH3 MILL
Hi to all
great cnc forum is this one!
first of all, I want to congrats to all that helps this forum to work
I'm just a beginner using MACH 3, I'm going to use it to make a school proyect, controlling some DC servo motors with a Gecko drive
but we start with one problem, we need to sincronizate two spindles at the same time, at diferent speeds,
is any way to configure another spindle in MACH3, something like
S1 1000;
S2 2000;
I need to use the step and direction outputs
any help will be very appreciated!
Tony
Old 08-16-2009, 06:51 PM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
Yes,
I made a 3 spindle plugin for Mach3, each can be set to run a different speeds, across the modbus. www.machsupport.com see forums, under Finished plugins.
scott
Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
Old 08-16-2009, 07:15 PM
el_tony33's Avatar
Smile OK!
I just was beginning to read the article that you published in the Mach3 forum,
Is this plugin able to make an output step and direction signal?? for both motor drivers?
I need this 4 signals for two rotary axes works simultaniously
Is there an counter or something that overflows? Because I need to operate them continuosly a long time (10 - 15 min) in some cases
thanks!
Tony
Old 08-18-2009, 11:26 AM
The Plugin is made to drive Standard VFD drives that take a 0-10V for spindle speed control.
if you want Step/dir spindles then use the extra axis of nativ emach to drive them, i.e. the Step/Dir for Spindle standard, and then use your B or C axis to drive the other step/dir spindle.
scott
Old 08-18-2009, 01:18 PM
el_tony33's Avatar
Smile Whoo ok!
OK! and what Gcode do I use to make a continous step and direction output?
how may I set the speed and direction of rotation?
Is a special Gcode?
I have investigated how to enable the other axis
thanks poppabear!!
Tony
Tags
mach3 control, mach3 problem, mach3 spindle
Setting up Spindle Control in mach3 UKRobotics Mach Mill 2 10-18-2009 04:34 PM
Setting up Mach3 + CNC4PC BOB + VSD-A-r2 ftec Granite Devices 6 10-13-2009 06:04 PM
Tool setting mach3 kayo Mach Software (ArtSoft software) 0 12-22-2008 05:20 PM
Basic Q's / Setting up Mach3 Thorpydo Mach Mill 3 09-24-2008 07:25 PM
setting 0,0,0 in Mach3 Mill sdantonio Mach Mill 33 04-01-2007 12:30 PM
