| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
So I notice that my machine won't keep its zero, so I write a program to confirm this. I leave it to g0 x0 y0 z0, g0 x1 y1 z1, and I let it run for an hour and it's still dead on from what I can see. The monitor had gone into power saving so I wiggle the mouse. The machine is still running, and it IMMEDIATELY loses it's zero and smashes the bit I have in the collet. It obviously lost a TON of steps on the up swing, meaning the zero point was now below the bed. What can I do to prevent this? Please please tell me there's a better solution than preventing the monitor from going into power saving. EDIT: Okay after disabling ACPI, something entirely different is happening. After running the same program, the DROs JUMP like crazy and the steppers just lock up and pulse on and off and lock back up repeatedly. Obviously they should increment by tenths but they're just flashing different values. Something seriously strange is happening. Last edited by sp1nm0nkey; 08-10-2009 at 01:23 AM. |
| Hi there, If running XP (could be similar in Vista), try turning off the screensaver function, better still, go to control panel and click on the "power options" icon , set the "turn off monitor" and system standby etc fields to never. Then disable hibernation too. Hope this helps. Good luck, pls let us know if you find a fix . Cheers. |
| Just a way out guess here, but it sounds like something might not be 100% right with your parallel port. A expansion parallel port is not expensive to test this. The parallel ports on the motherboard are subject to whims of the developers, often times making up what should be hardware parts, in software. Voltages and such can vary much more then they should. Even if it's not your problem, for $12 or so, it adds alot of additional functionality, like the aussie Z height setter. etc. If you can find all the stuff that triggers the problems, and shut them off. You've made a patch, but that's not going to cure it. |
| Thanks for the help. I found the same thing. Went to lunch and when I came back, screen saver was on, I started the program the machine proceeded to generate scrap!! The "Z" zero went to "-.050. I'll turn screen and power saver off and see what happens. |
If you are running a dual core processor it may be sharting the work and not doing it in the right chronological order. There is a way of telling a program to only run on one processor somewhere under the control panel - Ican't remember where. Help may find it for you. |
__________________ It looks like we're finally gonna get ALL the government we paid for! Lucky us! |
#10
| From the original post, it appears that the power management is the culprit. Did you turn off all the power management through the control panel? I think on some machines, changing ACPI requires a re install of the OS. I also don't recall seeing anyone using an Atom with Mach3 either, so not sure if it'll work correctly no matter what you do.
#12
| I installed the RightMark CPU Clock utility on my Dell D800 laptop, running Mach3 with a SmoothStepper and the EasyCNC driver board on a 3-axis PhlatPrinter. If I intentionally disable the RM Utility program, I will almost immediately start getting missed steps and fault ERRORs as soon as the CPU changes state. It's cheap, it forces the CPU to stay in a level state, and it works for me. http://cpu.rightmark.org/products/rmclock.shtml |
| Mach3 | dansa0561 | Spanish CNCzone | 2 | 01-31-2009 10:50 AM |
| Mach3 | Mooser | Tormach PCNC | 6 | 11-05-2008 09:20 PM |
| 4to eje con mach3 | dansa0561 | Spanish CNCzone | 3 | 07-31-2008 10:44 AM |
| G-Rex & mach3 | eloid | Machines running Mach Software | 7 | 03-14-2007 11:50 PM |
| Mach3 and USB | mikep608 | Mach Mill | 3 | 08-09-2006 12:56 AM |
