Old 08-02-2009, 07:01 PM
Richotech is on a distinguished road
Z-axis feed rate
Hi All,
I have a small engraver and need to have a slower feed rate on the z-axis as compared to the X and Y. I'm using a fine tip cutter on circuit baords and the tip is breaking off due to the z-axis driving the tip down too fast. Mind you I may need to slow the X-Y table down also. Is it easy to slow the z-axis while keeping the other two feed rates unchanged ?.
Brett.
Old 08-02-2009, 07:51 PM
ger21's Avatar
If you're g-code contains the feedrate, you can change it there. Or, you can lower the Z velocity in the motor tuning screen. Doing this will slow you're rapids, though.
Old 08-02-2009, 08:01 PM
Thanks Gerry,
I am using Eagle to make PCB's and the G-code converter for that allows separate X-Y and Z feed rates, but it does not seem to apply them to the z-axis ie. the feed rate is placed all through the code but only shows the faster X-Y feed rate.
Brett.
Old 08-02-2009, 09:27 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Can you post a sample of your g-code file, as a .txt file?
I've never seen code from eagle, is it standard g-code? If so, you could use the Replace option, in Win. Notepad, then go back & edit the header & footer g-code by hand.
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 08-02-2009, 09:34 PM
mcphill is on a distinguished road
Are you using PCBGcode? If so, I know for a fact you can have a different Z feed from XY. Sounds like you might not have something configured correctly.
Old 08-02-2009, 10:36 PM
Hi mcphill,
Thanks for your help. I am using pcb-gcode. and I have set different feed rates for X-Y and Z, but like I said it isn't coming up in the final code. I also notice the drill G-codes don't have any Z-axis code at all !. I have set it to use the Mach config, but maybe I'm have missed something.
Cheers.
Old 08-03-2009, 05:53 AM
G-code example from PCB-G-code
Hi Switcher,
I have attached a sample of of code. The full code is over 26000 lines so I cut it down to two pages. The feed rate only ever shows the X-Y rate.
Old 08-03-2009, 08:23 AM
James L is on a distinguished road
Eagle
I have had better luck loading PCB gcode files into Mach's Lazycam editor and making changes there. Took a little practice but I liked the control I had over how the programs turned out.
Old 08-03-2009, 09:13 AM
Originally Posted by Richotech View Post
Hi Switcher,
As a work-around, you could open the file in Notepad. Use "Find/Replace" (Ctrl-H) and search for "Z-0.2000" and replace with "F20 z-0.2000".
That will replace all your Z movements with a statement to slow the feed, do the Z move, and put the speed back up (the F2000.0 will stay on the original line.
Hope that helps!
I do a lot of "Find/Replace" on my files as I usually don't pay much attention to feed rates in my CAM program, and massage them once I am at the machine and "see how things" go.
As mentioned previously, you can also "speed limit" the Z axis in MACH3 itself, but that will limit the up travel as well as the down...
Max feed rate on NM-135? zaebis Novakon Systems 6 07-20-2009 06:34 AM
Need Help!- Axis feed rate drops to zero then back to normal TurboBlazerX Fadal 8 03-20-2009 08:52 AM
Problem- c axis feed rate on a turn /mill machine bike G-Code Programing 5 09-29-2008 06:57 PM
Need Help!- Feed rate Ovverride also Increases rapid rate. Korellibopper Machines running Mach Software 1 01-30-2008 05:37 PM
Feed Rate and Spindle Rate for this cut? DroopyPawn General Metalwork Discussion 20 11-21-2007 11:12 PM
