Old 07-28-2009, 07:06 PM
Wanna be
Hack is on a distinguished road
Changing computers
I will be changing computers for my router. Currently running Mach 3. Is it as simply as copying the config (or whatever file it is) over to the new install? Will that get all my settings to the new computer? Are these settings based on the computer at all? I understand that if I changer processors, etc that I may have to tweek things but I anticipate lead screw settings etc to transfer from one computer to another.
Am I correct in my thinking? What is the exact file that I need to copy and transfer?
Thanks all
Dan
Check out what I am working on at www.routerbitz.com!
Old 07-28-2009, 07:28 PM
ger21's Avatar
Should be mach3mill.xml
That should be all you need, plus your license file, and any plugins or brains if you're using them. Also custom macros if you are using any.
But for a plain installation, just the license and .xml file
Old 07-28-2009, 07:40 PM
Wanna be
Thank you,
I found the Mach3.xml file, but what about the liscence file? Is that the one called Mach1Lic.dat?
I appreciate your help.
Dan
Old 07-28-2009, 07:42 PM
ger21's Avatar
I think so. Since I don't actually have a running machine, I haven't purchased one yet.
Mac computers larry53 Computers and Networking 9 03-20-2010 02:28 AM
changing computers problem, frogger Haas Mills 3 03-05-2008 11:55 PM
Using old computers Solutions64 Computers and Networking 1 07-30-2007 08:23 AM
Uses for Old Computers Too_Many_Tools General Electronics Discussion 10 06-23-2006 11:23 AM
TIG and computers nervis1 Welding, Brazing, Soldering, Sealing 9 06-27-2005 01:25 PM
