Old 02-23-2005, 10:46 PM
Gold Member
JFettig is on a distinguished road
G12/G13 hole milling
I was glad to see that mach2 does hole milling, but very dissapointed to see what it ended up doing. Instead of an arc into the circle and arc out of the circle it goes strait in and gouges the side, I mite as well just plunge right into at the side.
Hole milling should look like the circle on the left, by doing it like this you dont slam into the side and make a big gouge. what mach2 does is like the circle on the right, starts in center and goes strait out.
Jon
Name:	hole miling.jpg‎
Old 02-24-2005, 07:21 AM
ger21's Avatar
Jon, if you use my AutoCAD macro and use G41 or G42 for your circles, it will add the lead in move similar to what you're showing above. Not a full circle, though, just a 90° arc. It doesn't use an exit move, though. Try it out and see if it works.
Old 02-24-2005, 08:35 AM
Gold Member
Ill give that a try. The way it works on all the big machines that I have run(Haas VF3, milltronics etc.) they do it like the picture on the left, start in the middle and go around either to the right or left and it makes a very nice circle. Even if it didnt go to the center but off to the right a bit or the left it wouldnt be so bad.
Jon
Old 02-24-2005, 08:45 AM
ger21's Avatar
Does it do that for each pass?
Old 02-24-2005, 08:52 AM
ger21's Avatar
Load this into Mach2 and look at the toolpath. 2 inch hole with a .25inch tool.
File Type: txt Circle.txt‎ (375 Bytes, 87 views)
Old 02-24-2005, 08:56 AM
Torsten's Avatar
Torsten is on a distinguished road
I noticed recently that some of the controllers offered this kind
of nonstandard fixed cycle.
In my opinion kind of redundant, you are much better of writing
your own macro for any kind of special purpose.
This way you get exacly what you want and don't have to contend
with sombody elses limited scope of suitability.
Good Luck
Old 02-24-2005, 10:33 AM
Gold Member
Here is what I am looking for, take a look at this code, it will make a very nice circle. I like these for finishing passes but not necessarily roughing passes.
This is using G3 instead of G13,
Jon
File Type: txt circle test.txt‎ (264 Bytes, 92 views)
Old 02-24-2005, 05:25 PM
ger21's Avatar
What are you using to create your code?
Old 02-24-2005, 06:24 PM
Gold Member
My fingers I actually used your program to try to make it work by selecting the order, but I cant select the direction very well, it goes up and down at the ends of the lines and stuff.
Jon
Old 02-24-2005, 08:49 PM
ger21's Avatar
Try this. Draw an arc for the lead in move. Draw another arc for the first half of the circle. Use pedit to convert to polylines and join them together. If you need to change the direction, join a straight segment going in the correct direction, then delete it. Now mirror it, and join the two halves. Then try my program. This should do what you want. Right now, it can't join two objects together. It probably never will, actually.
Old 02-24-2005, 09:05 PM
Gold Member
I dont understand about the direction and how it works with your program. I have not used it much, most of my programming I have been doing by hand.
Ill mess with it if I have time tonight.
Jon
Old 02-25-2005, 06:19 AM
ger21's Avatar
You have to draw your polylines in the correct direction. Or use the reverse polyline .lisp's I have linked to in my thread. You can check a polylines direction by going to the properties panel and clicking on the vertex line. There will be two arrows (after you click the line) that let you cycle throught the lines vertices. vertex 1 is the start of the line (and the toolpath).
Thread milling, can anyone help jtrav General CAM Discussion 16 03-06-2006 02:25 PM
Why would this machine be bad for milling? jevs Knee Vertical Mills 5 06-16-2005 10:49 PM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 02:43 PM
Milling a hole igorko General CAM Discussion 25 01-30-2004 05:55 AM
Thread milling cutterdia / hole ratio HuFlungDung Machine Problems, Solutions , Wireless DNC, serial port 3 12-31-2003 08:44 PM
