| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
| Set up both exactly the same and use Config>Slave Axis.
| Just set it up in Ports and Pins. You also need the motor tuning exactly the same as the X. It should work fine in the demo.
| Sorry for being so clueless. This is my first build and experience with mach3. I set the pins in pins and port for A axis and X axis the same. I then tuned the motors the same. I then set the hot keys for both axis the same. The motor tuning makes a difference on how the motors run but the hot keys do not change. What am I missing? |
| Am I making this harder than it needs to be? What I mean is am I going to have problems keeping the gantry square? Should I redesign it as a one motor drive belt or chain setup to eliminate constant realignment of he gantry? |
| Did you set up the slaving? That's all you need to do. If you run the machine within it's capabilities, you shouldn't have a problem.
#10
| In the Motor Outputs of Ports and Pins, is there a green check under "enabled"? That and setting the pins and port should be all you need to do to get it working.
#11
| Ger21- I am kinda in the same boat, I have two motors slaved together. X and A axis. All the settings are the same in Mach and in my servo drive (granite devices VSD-e) The output of each gearbox appears to be different. Any Ideas? Let me know if I should start a new topic. Steve |
| how turn stepper motors off when not in use in Mach 3? | uplb | Mach Software (ArtSoft software) | 3 | 01-01-2009 08:24 AM |
| Bridgeport stepper motors mach 3 setup? | wyobmf | Bridgeport and Hardinge Mills | 14 | 12-29-2008 08:15 AM |
| Is it mach 3, power supply or motors? | tauscnc | Mach Mill | 4 | 12-06-2008 08:17 AM |
| Problem- Do I need mechancial synchronizing dual belt drive? | kiwibum | DIY-CNC Router Table Machines | 9 | 05-18-2008 10:18 PM |
| Motors turn in Kcam, but not Mach. Any ideas? | cephjedi | Mach Mill | 4 | 04-16-2007 04:10 PM |
