| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I got a mid size mill a with controller (professionally built) but still struggling to get any connectivity PC-to-Controller. Standard parallel connection, straight through cable. Tried 4 different computers with onboard parallel ports and 2 plug in PCI parallel cards no luck. So decided to test parallel port pins on the computer side with an occilloscope. Launch Mach 3, scope charge pump pin (pin 9 in my case) = 6.8Khz !?!?! Close Mach3, reopen charge pump = 11.83Khz !?!? Sometimes it comes to 12.2Khz but never 12.5Khz claimed by Mach manual. My pulse freq reported by Mach in diagnostics is about 23656 to 24500 Hz. I tried to output a frequency on stepper X (pin 7 in my case) and it comes out properly each time and is inline with Mach freq. So when I dial 25000Hz on stepper X it shows exactly Mach 3 pulsing frequency, say 23656 Hz. But I am a little confused on the charge pump as it obviously way out of range. Does that mean my parallel port is no good? What is charge pump used for anyway? Can I disable it at all? How else can I ensure that the parallel port has suitable characteristics? I tried 3 different computers and on board parallel ports and they all output charge pump at 6.8Khz (sometimes jumping to 11.8Khz). Any ideas? |
| Zaebis, It is ok if the charge pump frequency fluctuates as long as it is present. Take a look at this, it will help you understand the charge pump function. http://cnc4pc.com/Tech_Docs/C4R6_2%20USER%20MANUAL.pdf What type of drive and breakout board do you have, it may not even have a charge pump option. More detailed information on your hardware would help. Do you have a instant messenger? Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| Jalessi thanks. So if I understood correctly CP has no other function than to monitor a "health" of Mach3 pulse generation. Is that what reset function goes by? I noticed when I hit Mach3 reset, charge pump stops. I guess controller interprets it as "need to stop". So it has to be there or controller will not do a thing right? I have Novakon 135 mill with CD300 controller. It has a breakout board inside it but I havnt looked at what actually is inside the controller. I cant seem to figure out if this is the fault of the controller or the parallel port itself. Is there any way to test parallel port "compliance" ?
| Zaebis, The charge pump was a after though in Mach3, some controllers or breakout boards have the ability to monitor charge pump activity less primitive ones don't. I am not sure if your Novicon controller requires the charge pump however it is enabled on pin 9 in the NM-135 Rev. 2.1 CD-300 (XML) file See attached charge.jpg Have you copied the NM-135 Rev. 2.1 CD-300 (XML) file into your C:\Mach3 directory? Are you loading the NM-135_CD300 from the Session Profile menu See attached .jpg Jeff...
| Zaebis, Please make sure your DB25 cable is straight through I.E. pin 1-1, 2-2, 3-3, 4-4, ....25-25 etc... You may have a acquired a null cable by mistake. Jeff...
| Problems connecting to the controller with Mach3 | zaebis | Machines running Mach Software | 2 | 07-09-2009 09:30 PM |
| Connecting bipolar motors to a unipolar controller | tommee10533 | Controller & Computer Solutions | 1 | 05-04-2009 10:30 AM |
| Newbie- Connecting an 8-Pin Stepper so a 6-Pin controller | sw_ | General Electronics Discussion | 2 | 03-10-2008 03:36 PM |
| Connecting controller with this motor | tom1975 | General Electronics Discussion | 0 | 09-16-2007 04:27 PM |
| Connecting a Controller Board | kpkale | Carken Products (Deskam, DeskCNC etc) | 7 | 07-29-2007 09:16 AM |
