Old 07-18-2009, 11:22 PM
Vogavt is on a distinguished road
Rotary table homing - How?
I've used the search function and looked at the entire site for: rotary table homing.
Found a few posts, but none really gave me anything to gon on.
How do you setup a rotary table to home to 0º? I have a Sherline 4" rotary table.
Any suggestions would be appreciated for where and how to mount.
Old 07-19-2009, 12:24 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Vogavt,
Enter A0 in the MDI window to home the A axis.
See the other image for Fixittt's 4th axis limit switch solution.
The mount may look a little primitive however it works.
Digikey sells the switches, they are fairly inexpensive.
Digikey Part Numbers:
Normally open magnetic switch part number
59020-010-ND
Normally closed magnetic switch part number
59025-040-ND
Magnetic cylinder for switch activation
57025-000-ND
Jeff...
ID:	84610   Click image for larger version
Name:	A axis home.jpg‎
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 07-19-2009, 09:26 AM
Wow! That was a quick response and I appreciate the effort for the screen shots and real life photo.
You listed both an open and a closed switch. Since my other homing switches are all NC, wouldn't it make sense to use that style? I'm assuming you mentioned both only for preference sake. Correct?
An added bonus with the picture of the rotary table for me was to see the fixture and how it's used. I now see why the mounts are angled on the sides. I thought they were to get some additional material out of the way to allow easier touching with the work piece. LOL!
Thanks!
Old 07-19-2009, 12:33 PM
jalessi's Avatar
Thumbs up
Vogavt,
Yes,
If your other homing switches are all NC, it makes sense to use the same style.
Most users would suggest and prefer N.C. to help eliminate noise issues as well as safety concerns.
The original poster "Fixittt", was kind enough to list all the available parts.
The four jaw chuck has a lot of versatility, very handy to say the least.
Jeff...
Homing a rotary axis? Harryman WinCnc 1 12-24-2008 11:19 AM
Help with rotary table woodsnskins Linear and Rotary Motion 1 12-18-2008 04:58 AM
Homing the 4th Rotary Axis "A" Paraprop Carken Products (Deskam, DeskCNC etc) 4 04-15-2008 05:01 AM
Cnc Rotary Table BAYWATCH-TIM General Metal Working Machines 2 10-31-2006 03:11 PM
Rotary Table Req h_2_o General Metal Working Machines 9 02-08-2005 01:11 PM
