Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: my thread of questions
    Gold Member
    Jun 2003
    Hi, I just bought mach2, Im having the worst of times diong just random weird stuff, I had my rapids turned up and I kept crashing
    the problem that I am having right now is when I do a M6 T1 or whatever, it stops for the tool change but does not apply the offset and shoots up and runs into the motor mount.
    -fixed-Also, I wanted to set up soft limits, I cant seem to get them to go, I set some dimentions and they just kinda sit there and I click the button and they dont even turn on.-fixed-
    Jon
    Mar 2003
    Shelby Twp, MI....USA
    I believe M6 calls a macro that you can edit to suit your machine. Can't tell you how it works exactly, though.
    Gold Member
    Jun 2003
    Im taking a look at industrialhobbies.com and they have a guide for something like this that Im taking a look at and working on.
    Jon
    Gold Member
    Jun 2003
    I used this little guide thing and got things worked out, Im liking it
    http://www.industrialhobbies.com/how...maticpart3.htm
    I tried to use feed per rev in turbocnc but it has you specify or recall a certain speed while its not cutting, kinda stupid, I did it in mach2 and its mad cool.
    Jon
    Oct 2004
    Quote Originally Posted by JFettig
    Jon
    Jon,
    Are you doing a G43 H "Tool #" after the tool change?
    If you would like to do it in the tool change macro you can add this to your M6 End Macro
    Code "G43 H" & Tool
    Hope that is what you are looking for...
    Brian
    Gold Member
    Jun 2003
    Barker, tahts what I wasnt doing, I read up and saw that and got confused, whether I was to put the tool number in there or the length or something.
    I set up scripts like industrialhobbies did so it puts the H# in for me now.
    Is it possible to do
    G43 H0
    G0 Z-.2
    Z0 being the very top of the z travel
    for the end of the program to raise the head up?
    thanks
    Jon
  7. #7
    Oct 2004
    The best thing to do at the end if you have a home switch is a G53 Z0.0 and that should take you back to your home switch.
    if you do not have a home switch it is very hard to set a retract...
    Hope that helps
    Brian
  8. #8
    Gold Member
    Jun 2003
    Yes I have home switches. Im use to running turbocnc, a G53 with a tool does nothing to the Z height, Im assuming that it does here? I usually use fixtures G54 and G55. Wouldnt I need to go to T0 (which its zero is at Z0 top of machine)?
    Jon
  9. #9
    Oct 2004
    Yes your tool length Comp has nothing to do with the G53 Move. G53 (non modal) is machine Coordinates and has nothing to do with fixture offsets as well. I have G53Z-.100 in my M6start and M6end so every time I tell the tool to change the spindle will go up as far as it can.
    Is this what you are looking to do? I have a few tool change macros in the yahoo group files sections if you would like to look at some others.
    Brian
  10. #10
    Gold Member
    Jun 2003
    That is similar to what I want to do, my tool change macro that I got from industrialhobbies is very similar, goes up to safe z or toolchange position. Its just the end of the program that I am worried about right now, Ill try the G53 Z-.2 in my when Im getting ready to run some parts
    Thanks,
    Jon
  11. #11
    Gold Member
    Jun 2003
    quick question:
    Do I need to cancel canned cycles? I have never done it with turbocnc and dont recall doing it on any of the other cncs that I have run, let me know, Im using a G83 btw.
    I mite as well pop it in there for the time being, its just one of those things I would rather just not type out every time if its not needed.
    Jon
  12. #12
    Gold Member
    Jun 2003
    G53 didnt work it stuck my drill right back down to zero on the part when it finished. I dont have my z set for the fixture, I use machine zero to set my tools on because I chanage fixtures often
    Jon
  1. Thread mill programming software?
    By cncwhiz in forum G-Code Programing
    Last Post: 12-31-2008, 02:48 PM
  2. a million questions about starting cnc
    By Data in forum General Metal Working Machines
    Last Post: 04-14-2008, 12:49 PM
  3. Thread milling, can anyone help
    By jtrav in forum General CAM Discussion
    Last Post: 03-06-2006, 03:25 PM
  4. Newb with thread milling questions using the helix(conversational)
    By metalbytch in forum General Metalwork Discussion
    Last Post: 12-01-2005, 06:30 PM
  5. Thread milling cutterdia / hole ratio
    By HuFlungDung in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 12-31-2003, 09:44 PM
