Old 07-10-2009, 01:55 PM
bullethead67 is on a distinguished road
Mach3 with on board graphics
Do i absolutely have to have a external graphics card? I was looking at the dual core atom mini atx boards on newegg for 80 bucks. It has a on board graphics and is a machine somewhere between laptop and desktop. It is a dual core with hypertreading and a decent graphics chipset. I would like to build my own control panel with the computer inside but dont want to get almost finished then find out that i absolutely have to have a external graphics. I know laptops are not recommended because of their "power saving features" but i dont know exactly what power saving features they mean? The dual core atom is a low power unit so i am concerned there too. It has a parallel port so if it would work then it seems like the perfect choice.
Old 07-10-2009, 02:27 PM
mcphill is on a distinguished road
On board video is not an issue. Laptops are a problem because of power saving techniques they use to save battery power. This affects the way the signals are sent to parallel port, and they have a lot of "sleep" type timeouts that affect whether hardware is ready when you need it. Board level computers should not have this issue. I bought an Intel Atom all-in-one computer to use with MACH3 myself, but have not had the time to build it up yet.
Old 07-10-2009, 02:31 PM
ger21's Avatar
Some people are using Atoms, but using the Smoothstepper to generate step and direction signals. They don't have parallel ports, do they?
Old 07-10-2009, 02:40 PM
The board I got does have a parallel port. Here is the board and specs:
http://www.intel.com/products/deskto...D-overview.htm
Old 07-10-2009, 03:26 PM
heres what im looking at.
http://www.newegg.com/Product/Produc...tel-_-13121359
Old 07-10-2009, 06:20 PM
Same one. There were cheaper sources when I got mine (this past May).
Here's one:
http://www.antonline.com/p_BOXD945GCLF-NX_513026.htm
Cross check cheaper stores with ResellerRatings.com prior to purchase if you are not familiar with them.
Need Breakout board to control Mach3 Mongkol General Electronics Discussion 1 04-19-2008 12:38 PM
Which breakout board to use with G203V and Mach3? teamtexas Gecko Drives 3 02-19-2008 06:49 AM
Router Speed Control + Mach3 + Breakout Board Dingo745 General Electronics Discussion 7 06-19-2007 08:58 PM
"BRAKE BOARD" NEW Design for MACH3 Chivo General Electronics Discussion 1 04-08-2007 12:01 PM
Graphics danbor004 Fanuc 3 04-10-2006 01:45 PM
