Old 06-28-2009, 05:10 PM
jafc76 is on a distinguished road
Aspire one+USB to ExpressCard+ExpressCard EPP Parallel Port
This is my question...
I wanna control my machine with an Acer Aspire One, it doesn't have ExpressCard slot and Parallel port neither so I don't know if I can use an USB to ExpressCard adapter and an ExpressCard EPP Parallel Port.
These are examples: (The pictures are not with ExpressCard Parallel Port, but you can see the idea)
http://xs133.xs.to/xs133/08463/usb_t...apter_1424.jpg
http://www.evdoinfo.com/images/stori...xUSB_EX720.jpg
http://www.darkwire.com.au/assets/im...ressCard32.jpg
I have the electronics with Parallel Port so I'm not going to use the Smooth Stepper, maybe for my next machine.
Do you think that it can work?
Thanks!!!
Juan
Old 06-28-2009, 05:20 PM
daedalus is on a distinguished road
I havent tried such a setup, but i would assume that you will have added latency and non-determenistic delays from all the bridges before the parallel port, which may be a showstopper with mach.
I would go a different way, you have a compact-pcie card slot in it, and you can get compactpci-express to pci bridges, then use a pci parallel port. That said it might be less grief to get a small pc for the machine controller.
EDIT: it may be simpler to get one of the usb based step generators that are supported in mach, dont have much experience with that, but ask around, im sure ppl here do.
Old 06-28-2009, 05:42 PM
But this laptop doesn't have connector for the mini PCI-E card.
http://www.noticias3d.com/articulos/...io_minipci.jpg
It's strange!
Juan
Old 06-28-2009, 06:02 PM
ah, i didnt count on them being so cheap as to not fit the connector SmoothStepper or similar might be the best option for you, as its usb based, and does the step generation itself.
Old 06-28-2009, 09:05 PM
Hahaha!! It's true, too chip computer.
I was looking alternatives for smooth stepper but maybe nothing better.
Thank you very much
parallel port or parallel universe bruno34 Taig Mills & Lathes 5 04-15-2009 10:58 AM
parallel port wantsout General Electronics Discussion 15 09-23-2008 11:49 PM
ExpressCard Parallel adapter? GMTool General CNC (Mill and Lathe) Control Software (NC) 1 03-24-2008 11:41 PM
Need Help!- ExpressCard Parallel Port for notebooks? jeffmorris DIY-CNC Router Table Machines 2 03-20-2008 07:10 PM
Parallel port Aldoseri BobCad-Cam 11 03-13-2006 10:10 AM
