| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
I'm running Mach3 in order to drive my G540 and can't seem to get my steppers to spin. I've tried this on two machines, each running the configuration from geckodrive.com. Machine 1: In BIOS, parallel port set to EPP+ECP mode Charge pump not pulling the drive out of fault Scoped the parallel port, pin 2 (X axis step) seems to be stuck high while jogging Seems to be activity on other pins... can't remember which Pulling the plug on the drive causes mach3 to fault... so it seems to see the interface Machine 2: In BIOS, parallel port set to EPP mode Charge pump has no problem pulling the drive out of fault Something keeps activating mach3's e-stop request... it won't come out of reset I did some bench testing of the drive... and the motors spin when I just tickle the step pin with a function generator, so this would seem to be a problem on the computer side. I've also tried bi-directional mode on machine 1 and it doesn't make any difference. |
| Sp1nm0nkey, Is pin 10 connected to Pin 12? Did you copy the G540b.xml file to the Mach3 directory? Are you loading the 540B profile when you start Mach3? Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| Are you sure you have a straight through cable, its easy for a vendor to give you a null or lap link data transfer cable by mistake.
| Need Help!- G540 problem, steppers not moving | CS900 | Gecko Drives | 36 | 11-13-2008 10:38 AM |
| board wont move steppers | guido_kp | Hobbycnc (Products) | 4 | 05-22-2007 04:19 PM |
| Move your steppers. Free XP progam. Simple | zippys | General CNC (Mill and Lathe) Control Software (NC) | 1 | 05-21-2007 06:32 AM |
| Does higher voltage allow steppers to move faster? | SCCoupe | DIY-CNC Router Table Machines | 2 | 03-21-2005 11:27 AM |
| The X-Axles... to move or not to move! | Wild4aces | Mechanical Calculations/Engineering Design | 1 | 03-18-2005 01:26 PM |
