Old 06-10-2009, 08:43 PM
corneliusbrown is on a distinguished road
MOTOR TUNING
I'm very confused at this point. Ive read so many different things, my head is spinning but I'd like to learn.
My motors are 200 steps per rev. my driver board is set to 1/8steps
my threaded rod is 1/4-20
I'm thinking i need 32000 steps per but i'm lost in every other category.
Mach3 is set to MM
Could someone give me:
Steps Per, velocity (mm/min), accel (mm/sec) step pulse, and dir pulse?
or at least point me in the right direction?>
Old 06-10-2009, 09:20 PM
ger21's Avatar
Steps/mm = 32000/25.4 = 1259.8425
Step and Dir pulse depend on the drive, but are usually set between 2 and 5.
Velocity and accel vary from machine to machine, and are usually set by trial and error. Start with a very low accel and slowly increase velocity until steps are missed, then back off 20-30%. Then increase accel until maxed, and again, decrease by 20-30%.
Old 06-10-2009, 10:21 PM
THANK YOU
ger21:
you nailed it. I've only used a sharpy taped to the router to measure w/ a caliper but the results are dead on and are good enough for now.
Now for velocity and acceleration...which i will figure out for myself.
Thank you!
Old 06-10-2009, 10:26 PM
rwestbr is on a distinguished road
Watch this great video....it will help you get it calibrated, perfectly and easily....
Robert
New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR) MDF_Markazi Mach Software (ArtSoft software) 7 04-30-2009 02:15 AM
Need Help!- Help with motor tuning harrisam DynaCNC 8 05-09-2008 08:17 AM
Motor Tuning ??????????? Biggermens Mach Software (ArtSoft software) 2 03-14-2007 09:52 PM
Motor Tuning cookja01 Machines running Mach Software 1 03-07-2007 02:27 PM
Motor Tuning PEU Mach Software (ArtSoft software) 3 09-26-2005 11:48 PM
