| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
| My understanding is that there is a background process (ie. "watchdog") that is monitoring the parallel port driver performance. If the driver starts under performing, the watchdog alerts you to that fact. This can happen because your machine has other processes competing for resources. Perhaps you're running other programs, your screensaver has kicked in, etc. You can either turn off the watchdog, or try and disable other processes/applications that may be interfering with the driver timing. If you're already running a very "clean" machine, then it might be telling you that you need more CPU power, RAM, etc. Steve |
| It is a very clean machine with 3ghz processor and half a gig of ram. Interestingly these errors seem to become more frequent when I'm running the spindle. Do you reacon its possible that noise from the VFD could cause such an error ?
__________________ Dom http://www.ukrobotics.com/projects |
| I had a few of those....I'd set the frequency wrongly to 100hz in ports and pins.....I say this as it went away completely after I took the advice of operator/check config. Yours may be something else....worth a try for nowt
__________________ Keith |
| I was running at 100khz and moved down to 75khz to solve a problem with the servo drives being 'jerky' however I cant go any lower than 75khz else I wont be able to run my servos at their rated max speed; not without messing about with 'electronic gearing' and stuff anyway and then i'll lose resolution.
| 75 K is a pipe dream on a PP..... goto a Smooth Stepper or Galil for speed with High count encoders. scott
__________________ Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/ |
| Newbie- Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver? | joprinz | General Electronics Discussion | 4 | 04-28-2011 03:57 AM |
| tl-2 program integrity error and program data error alarm #'s 212 250 need help | CNChelp | Haas Mills | 12 | 03-14-2010 08:19 PM |
| Need Help!- Matsuura Mc500v seq error/magazine error | mc500v | General Metal Working Machines | 10 | 01-08-2010 01:35 PM |
| Driver Watchdog Triggered???? | rweatherly | Mach Mill | 1 | 07-01-2008 03:31 PM |
| Keling 5056 Driver Error HELP | Cartierusm | Automation Technology Products | 6 | 12-19-2007 09:54 PM |
