| Mach Software (ArtSoft software) Discuss Mach 1 , 2 and the new Mach3 here NC software here! |
| Hi, What type od drives are they, step motor drives or servo motor drives? If the drives are digital with a step & direction interface then yes, you can use them directly - but if this is a servo machine then they're probably not. You need to find out how the drives are controlled, ie. step&direction, +/-10V, PWM, etc then we can figure out if and how they can be interfaced to Mach3. /Henrik. |
| Jim, If it is Step and Dir drives mach will drive them natively, (note you have high count encoders you should consider and exernal board like the Smooth Stepper). If the Drives take an Analog signal, you can do it also, BUT, you will need something like the "Galil" motion board, this is a little more complex to set up, but worth it in the long run, and they can get expensive quickly. scott
__________________ Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/ |
| You may have a problem with the encoders or scales as Heidenhain use three different formats for their feedback signal, standard TTL (5v), 11ua and 1v p-p sine waves. Al.
| Mitsubishi TRA41 servo Drives - interface help please | kudos | Mazak, Mitsubishi, Mazatrol | 14 | 03-22-2012 08:47 PM |
| MACH3 closed loop encoder interface | RomaxxCNC | Product Announcements & Manufacturer News | 1 | 05-28-2010 05:59 PM |
| Heindenhain tnc 351 for sale complete | capsteve | Bridgeport and Hardinge Mills | 1 | 05-04-2009 10:36 AM |
| Mastercam post for Heindenhain please help | gasho | Post Processor Files | 1 | 03-01-2009 01:13 AM |
| will mach3 work with gecko drives | derkiow | Gecko Drives | 11 | 11-15-2006 01:29 PM |
