  #13   Ban this user!
Old 01-31-2005, 10:13 PM
Moondog is on a distinguished road
Ger... so by the looks of it.... even with no Step Multiplier reduction I should still get reasonable IPM's?...
Initially I'll only be using a Makita router. Hope to then upgrade to a HSD Spindle.
Old 02-01-2005, 06:26 AM
ger21's Avatar
If all your calculations are right. I only looked at the 180 steps/mm, I didn't check the rest. We've got 2 9HP HSD's on our machining center at work. I cut 3/4" plywood and mdf in 1 pass at 400ipm. (The machine won't go any faster, or I would )
Old 02-01-2005, 06:41 AM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
I caculate:
0.0055mm per pulse
multiply by 45000 pulses/second (0.0055*45000) = 247.5mm/second
Divide by 10 to get cm/second = 24.75cm/second
Divide by 25.4 to get Inches/second = 0.974 Inches/second
Multiply by 60 to get Inches/minute = 58.5 IPM
Maybe I'm going mad.
Regards Terry.....
Old 02-01-2005, 06:46 AM
MrBean's Avatar
Gold Member
Originally Posted by Moondog
lte me get this right...Mach2 max at 45,000 pulses per second.. that = 2,700,000 per minute... If my X drive is .005555 mm per step. then for say 300 IPM i need..
300 IPMinches = 7620mm per min... / .005555 = 1,371,737 steps per min..... half of mach 2 output... my Y is less than half the X..... so I still have 1,320,000 approx for my Y & Z...
does that sound right?..
300 inches is 7620cm, not mm.
Regards Terry.....
Old 02-01-2005, 06:51 AM
ger21's Avatar
Regards Terry.....
Terry, divide centimeters by 2.54 to get inches. Multiply your ipm x 10
Old 02-01-2005, 06:53 AM
MrBean's Avatar
Gold Member
Yep I'm going mad........HAHA.
Old 02-01-2005, 06:55 AM
MrBean's Avatar
Gold Member
I'm out by a factor of 10. Ooops.
What's needed for complete setup? LeeWay Gecko Drives 1 03-09-2005 08:38 AM
Stepper Resolution Max DIY-CNC Router Table Machines 5 09-05-2004 03:06 AM
PayPal PLEASE READ THIS NOTICE CAREFULLY. WallCrawler CNCzone Club House 13 07-30-2004 08:59 PM
High resolution encoder ToyMaker General Electronics Discussion 5 06-11-2003 02:04 AM
