Results 1 to 11 of 11
Thread: Problem reinstalling Mach 3 Please need help
    Jun 2003
    U.S.A.
    Been using Mach 3 awhile. This week started having problems when running long or complicated programs. Had a couple power outages last week when computer was on thought maybe Mach 3 became curropt during an unexpected power outage. Tried to reinstall got the blue screen of death. Uninstalled everything I could. Deleted all files and folders I could. Deleted driver in device manager. Now when I try to install I get an error "A decompression error has occured (#5). Now I can't seem to get past this. Any ideas what I screwed up and how to fix? Thanks Ron
    Registered LeeWay's Avatar
    Jun 2004
    I would run a check disk on your hard drive first.
    Then I would download a new copy of Mach 3 and go from there.
    Lee
    Jun 2003
    U.S.A.
    Lee,
    Thanks for your reply Did a check disk. It said on level 2 of 3 that was correcting error in index $130 for file 14473. When done tried reinstall from new download of Mach, no go. went back to chkdsk and everytime I run it I get the same "correcting error in index $130 for file 14473. I'm guessing maybe I have a hard drive going south? Is that what it's trying to tell me? Thanks Ron
    Jun 2004
    That is kinda what it sounds like, although I never had one go south due to errors. I have run some HD with bad sectors and they did okay, once it knew not to try and write to those.
    You might try to defrag it.
    Lee
    Jun 2003
    U.S.A.
    Lee,
    Tried Defrag. No errors show up with it but it didn't help any either. Still same errors and still same correcting error in index if I do a chkdsk again. I'm stumped. Guess next week I'll have to go used computer shopping, can't justify a new one to go down in the dusty nasty shop enviroment. Thanks for your help. Ron
    Mar 2003
    Shelby Twp, MI....USA
    I'd try to reinstall the OS before you buy a PC. If the drive is failing, the OS probably won't install either.
    Aug 2006
    us
    It sound like a bad sector on the disk or a bad head, time for a HD replacement? Depending on the hard manuf. you can format, but it has to be to level 0 of the drive, Seagate an WD have these utilities. Repartition the drive and install OS. But the time you fart around will all this, just buy a new drive if the PC is worth it.. On another note, blue screen of death in Windows is usually a memory R/W problem or bus conflict, you said your in a dirty place, pop out the memory and processor, clean connections, blow off motherboard and power supply and give it a try. Otherwise, best of luck, Tiger Direct alway has some decent deals.
    Chip Coale
    Jun 2003
    U.S.A.
    Thanks for the input guys. Would try to reinstall the OS but don't have any disks to do it with. Was used computer when I bought it. Will try the blow out and clean connections in morning to see if that helps. Would try to put in a new HD, that would be quick and they're cheap except no OS disks to get her up and running again. Ron
    Aug 2006
    us
    I assume you are using XP, you can buy an OEM version online fairly cheap, if using an older OS, then I assume old hardware, junk it and buy another PC, you can still buy systems that are downgrade to XP, being that Vista does not play well with most CAM packages
    Chip Coale
    Jun 2008
    Quote Originally Posted by foamcutter View Post
    After reinstalling Mach did you reboot before trying to "run" Mach? This is a "must do".
    You maybe could uninstall Mach , driver, folders, do a "registry edit" and delete all references to Mach. Reinstall, reboot, run Mach. Beware "regedit" could FUBAR everything if you screw up.
    Good luck
    Jun 2003
    U.S.A.
    Hello again,
    Yep using XP. Will look online for OEM to see if that will work. Yep did the big reboot when I did the reinstall. Have not tried the regedit yet but probably will since I have nothing to loose. It's broke already making it FUBAR broke won't really hurt anything. Thanks again for the ideas, all your help has been appreciated. Ron
    1. Replies: 6
      Last Post: 06-05-2008, 10:50 AM
    2. reinstalling x axis servo and encoder
      By fcycles in forum Milltronics
      Last Post: 12-11-2007, 01:30 PM
    3. Homing Problem After Reinstalling Servo
      By Productos in forum Bridgeport and Hardinge Mills
      Last Post: 10-19-2007, 04:29 PM
    4. Lots of Problems after reinstalling Galil card
      By 69owb in forum CamSoft Products
      Last Post: 05-06-2007, 10:09 PM
    5. Reinstalling timing belt pulley
      By snapman in forum Linear and Rotary Motion
      Last Post: 01-03-2007, 11:46 PM
