Old 05-16-2009, 11:24 AM
wrloveyuelin is on a distinguished road
Mach3 and Sigma II
I have 3 YASKAWA Sigma II drives and the Step Direction from are not labeld that way they are labled as follows
Puls \ pin 7
CW >
Puls / pin 8 (ref to Gnd)
Sign \ Pin 11
CCW >
Sign/ Pin 12 (ref to Gnd)
does this mean that pin 7 is the step and pin 11 is the Dir with a common to Gnd?
Old 05-18-2009, 12:37 AM
barbque is on a distinguished road
Sigma’s like a differential input. In the SigmaII book check out chapter 5, page 17. Look for the line driver example 1. You could use a SN75174 or a MC3487 to drive the step and dir signals.
If you used Gnd you would end up with a unstable system due to noise. I don't recommend using Gnd.
Also don't forget to take care of CLR input. You will need to drive the signal hi or low to get the drive to accept Puls and Dir signals.
Kris
Old 05-18-2009, 08:34 PM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
"I have 3 YASKAWA Sigma II drives and the Step Direction from are not labeld that way they are labled as follows
Puls \ pin 7
CW >
Sign \ Pin 11
CCW >
Sign/ Pin 12 (ref to Gnd)"
Pulse = step, Sign = Dir, you have a differential input there, where the "/" pin is your NOT pin. Look at the input diagrams of your drive. Look at the direction the "Optos" are facing. If you using a BOB like one from CNC4PC, you can Change the polarity of your "commons". to match your drive. tie the two grounds for your Nots "/" (use shielded cable) to the common, and send out your Step to the Puls pin \, and your Dir to the Sign pin \
scott
Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
sigma motor ? fido Bridgeport and Hardinge Mills 0 01-15-2009 01:22 PM
Sigma stepper specs ohdiemaker Bridgeport and Hardinge Mills 2 12-26-2007 12:28 PM
Large Sigma steppers? DennisCNC Stepper Motors and Drives 0 03-17-2007 07:08 PM
Sigma Instruments mcan Stepper Motors and Drives 1 01-24-2007 03:13 AM
Sigma Vs. Superior on Gecko 202 arriflex Bridgeport and Hardinge Mills 2 10-12-2006 04:28 PM
