Old 05-13-2009, 09:20 AM
gavztheouch is on a distinguished road
Will Mach 3 work with my drive input.
Hi I have a couple of Panasonic AC Servo "MUDS" drives, in the data sheet it says it takes the following input signals for positional control.
1) Quadrature (A and B) input
2) CW (PULSE)/CCW (SIGN) pulse input
3) Command pulse (PULS)/Sign (SIGN) input
Will any of these be suitable for Mach 3 output? PULS and SIGN sounds very similer to STEP and DIR but they could be nothing like each other?
Cheers
Old 05-13-2009, 11:23 AM
H.O H.O is offline
H.O is on a distinguished road
Yes, Mach3 outputs Step / Direction (pulse & sign) by the default so if you set the drive to accept that it should work fine.
Old 05-13-2009, 11:27 AM
Thanks H.O
No U-axis input possible in Work offset Stebedeff Fanuc 4 01-28-2009 11:40 AM
MACH 3 Spindle speed input billyfriday Index CNC lathe 0 12-31-2008 05:10 PM
Need Help!- how to pause mach 3 to wait for an input from pasma bthomps5 Mach Software (ArtSoft software) 2 08-31-2008 11:44 PM
MACH 3 USB INPUT CONFIGURATION coremfg Machines running Mach Software 5 01-08-2008 08:04 AM
will my drive work with mach 3 Fabric8r Mach Mill 1 02-01-2006 05:46 AM
