Results 1 to 3 of 3
Thread: easy to answer question
    Apr 2004
    Lincoln, Ne
    where in mach 2 can you reverse the direction of you axis so that going in a certain direcion is + instead of - ?
    Gold Member MrBean's Avatar
    Oct 2003
    UK
    Should be in "config" menu >> Motor reversals.
    Regards Terry.....
    Oct 2004
    The other way is to change the "Low Active" check box by the DIR pin.
    FYI, This is the only way to do it in Mach3...
    Quote Originally Posted by senor J.
    Happy Chips
    Brian
  1. Extremely basic machining question.
    By touser in forum General Metalwork Discussion
    Last Post: 06-19-2005, 01:51 AM
  2. Easy question, Hard solution
    By CBNDude in forum Mechanical Calculations/Engineering Design
    Last Post: 06-10-2005, 02:04 PM
  3. question about thk rail mounting
    By mwp in forum DIY CNC Router Table Machines
    Last Post: 03-10-2005, 01:10 AM
  4. Question about power supplies
    By dowling177 in forum General Electronics Discussion
    Last Post: 01-28-2005, 08:01 AM
  5. Hobbycnc controler question
    By chas in forum Hobbycnc (Products)
    Last Post: 09-09-2004, 06:00 PM
